Quick question from a newbie
skelly
I bought my '64 Sprite a couple of weeks ago and noticed the coolant temp got a bit high (195) on an extended drive. At the same time my oil pressure dropped fairly low (under 20). I installed a summer thermostat rated at 160 degrees to bring the temp down. The thermostat that came out was a 180 degree one. After installing the summer thermostat the gauge now reads 180 degrees after warm-up . Is it possible for the water temp gauge to read 20 degrees high? BTW, I changed the oil to Valvoline VR-1 20W-50 and my oil pressure stays at or above 40. Can the water temp gauge be calibrated? Thanks for the help.
RickB
How was the weather? If it was cold out then I would take a look at the radiator.
If it was hot then I'd say 195 really is pretty good.
I've got a 190 thermostat since I drive in cold wet a lot of the time and I want my heater to get as hot as possible. That's in my Midget
However in my MK2 Sprite the temp stays about 190 IIRC.
nomad
Part of the fun of just about any british car! Least by my experience, they tend to run a bit on the warm side. I would say your temp readings are accurate. Just keep an eye on it and if it gets close to boiling you may want to back off the throttle a bit. Either that or look to changing radiators. There are a few things to watch for. First is your ignition timing right? Carb setting pretty close?
A electric fan will probably help keep things cooler in city traffic since the early fan shroud dosn't do that great a job. If you want to do more, like change radiators, there are options this group will be happy to help with.
I believe Barney Gaylords "MGA Guru" site suggests you put a piece of tape over the guage if it really bothers you!!! (My MGA is terrible for running hot but then it needs the block cooked out as well!)
Kurt.
skelly
skelly
It was about 90 and I was running at highway speed. The temp dropped a bit once I slowed down. I'll keep an eye on things but the new thermostat lets it run lots cooler. I do need to put a piece of tape over my tach. It is way off. Drives me crazy looking at it. It will be fun to get things all sorted out with this car. Thanks for your comments.
JPSmit
And, if your oil pressure is below 20 at speed, there is probably a rebuild in your future. For now, you might want to add a litre of Lucas oil additive. I do and it boosted my pressure just enough!
bthompson
That's true. Under 20psi at hot idle is normal, but with any RPM at all your oil should be above 40. If it stays low, odds are that the bearings need refreshing.
If you want a quick-and-dirty way to check your temp gauge, just pull the sensor bulb out and plunk it in a mug of boiling water with a candy thermometer in it. Keep an eye on the gauge and the thermometer as the mug of water cools off, and see where the gauge sits at every, say, 10 degrees. That'll give you a good idea just where your temp really is.
DRH
For the desert guys, most DIYers go for the 160 degree thermostat. But that doesn't mean you're going to get 160 degrees on your temp gauge in any summer. What that means is the valve opens at 160. The warmth of the day may still give you 185 degrees....or 200 degrees plus in the engine. In order to compare the thermostat against the temp gauge, you need to make the test in the cold of winter. That way, the engine is operating at its lowest temp that the thermostat allows and the temp gauge should reflect that. If it's not boiling over, it's probably just fine.
Pythias
195 degrees at high speed on a 90 degree day is not bad at all, especially if you have your heater valve closed off.
Pythias
About 4 years ago though, I was stuck in a Seattle traffic jam, blocks long, (mariners game) late July. The ambient temp was 95 degrees or hotter and the car never went over 205 degrees. This is without an oil cooler, as Paul A. made me take it out when he rebuilt the engine. He maintained that 1)the cars don't need it, and 2)I would never be able to get all the oil out on when I changed oil, so I would ALWAYS be running dirty oil. Instead I had the radiator re-cored and have never had a heating issue, though this IS the PAC-Northwest.
skelly
skelly
After switching to a 160 degree thermostat, I did a fairly long drive at highway speeds and the coolant temp kept rising to 200 degrees and over. Yikes! I want to be able to drive this car anywhere so I decided to install a new radiator. I also put the 180 degree thermostat back in so I can have some heat in cooler weather. Before I filled the system with antifreeze, I tried the hot water and candy thermometer check of the temp gauge. It read 5 degrees high from 200 down to 170. After filling the new radiator and running to operating temp, I topped it off and went for a long highway drive with air temp of 90 degrees. The temp gauge rose to 190 and stayed put. After taking into account it reads 5 degrees high, that makes it running at 185 degrees both city and highway. I also installed the six blade plastic fan. Hope these changes allow it to operate at a temp that I feel safe with. Thanks for all your suggestions.
Jay
T MGB Quick question about something that don't really matter just want to know. MG 9
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
S MGB 1980 MGB quick question MG 2
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR6 Quick TR6 alternator question Triumph 6
M Quick tachometer wiring question on a '65 Spridgets 10
Willie_P Quick question: rear diff TR 3/4 Triumph 6
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
MCNX_BFF Quick catch-up and trailer question Triumph 8
PatGalvin Captive nuts?? quick question Triumph 7
JPSmit Quick Spark plug question Spridgets 10
Sarastro Quick dumb transmission question Spridgets 9
T Quick fuel pump question - mounting angle MG 3
T TR4/4A TR4a retrofitting of roll bar - quick question Triumph 1
bigjones HS4 - quick question MG 6
JPSmit Quick HS4 Question MG 2
T don't have my book, quick torque question Triumph 5
JPSmit Quick Transmission question Spridgets 2
L A quick question for you UK/European LBCers Spridgets 0
Jim_Gruber Quick Carb Question Spridgets 16
bigjones Quick alternator question Spridgets 16
livinginthepast Quick question on setting fast idle/balancing carb Spridgets 21
M TR2/3/3A Quick TR3 Question .Trans cover color Triumph 6
D Quick Question C to F Restoration & Tools 4
JPSmit Quick Carb Question Spridgets 2
theleisure quick clutch question Spridgets 10
T Quick 1275 question on a Mini motor Spridgets 2
tosoutherncars HEEELP! Quick soft top question Spridgets 7
T TR4/4A Quick question on TR4 battery Triumph 7
JPSmit Quick question #2 Emergency Brake Spridgets 1
Stewart Quick wiring question MG 6
cmacmillan TR6 Quick question on Haynes for TR6... Triumph 3
J TR4/4A Quick TR4A wiring question Triumph 6
jlaird Quick question Spridgets 5
jjbunn Quick Speedo Question Triumph 14
JPSmit Quick Question - rear hub torque Spridgets 4
mlarnoldTR6 Quick question Triumph 2
RickB MGB Quick tire size question - MGB MG 10
JPSmit Very Quick Question - rear oil seal Spridgets 2
P Quick Coil Question. Triumph 3
JPSmit Quick rear brake question Spridgets 56
T A quick silly Crypty question. Triumph 3
Webb Quick Alternator Wiring Question Triumph 3
Trevor Jessie Quick question...really [about line fitting] Spridgets 14
tosoutherncars Quick question - 1500 wiring for coil Spridgets 7
tosoutherncars QUICK QUESTION - manifold bolts Spridgets 3
Sarastro Just a quick, dumb generator asssembly question Spridgets 2
JPSmit Quick Spring Question Spridgets 10
