TR4/4A Quick question on TR4 battery
tdskip
Need to get a battery for the TR4 BUT the car is at a shop and I've forgotten which terminal is on which side.
If you are looking at the engine bay from the front (radiator) which side is the positive terminal on?
I 'think' it is the right hand, drivers side.
Yes/no?
TR4nut
If you haven't converted the ground from positive to negative, the positive side or ground is on the drivers side. Negative then runs down by the carbs to the starter solenoid.
I think there's room for the terminals to be on either side, just depends if you want the terminals to be close to the hold down bar, or close to the bulkhead.
Randy
TR4
I would add if the previous owner had not converted to negative ground either. My previous owner did the conversion on my car so it is now negative ground.
Lou Metelko
Both the TR4 (positive ground) and the TR4A (negative) used the same size battery. It was just turned around; posts in front or at the rear. A group 27 (original) size fills the shelf much better than the more common group 24.
Lou Metelko
Auburn, Indiana
65 TR4A
Stig
I have a service bulletin T-65-15 about grounding. It is 3 pages long and starts with:
General
Current practice on vehicles of British design is to ground the positive
terminal of the battery, while other countries have retained, or reverted to,
the use of negative polarity for the ground circuit.
With the increasing use of polarity sensitive devices, such as silicon diodes,
transistors, and electronic components in vehicle electrical equipment, there
are advantages to be gained from the early adoption of a standardized vehicle
grounding system, particularly in the service field.
The reasons which originally prompted the adoption of positive ground on
British vehicles, although still being valid, are now of less practical
Importance owing to improvements in electrical design. In the interest of
standardization most vehicles manufactured in England will in the future change
over to a negative ground system.
Two manufacturers have already introduced production models with negative ground
equipment. These are the David Brown 3 cylinder, 880 implematic tractor, with
conventional D.C. equipment and the Jaguar 4.2 litre Mk. X and E-types with
A.C. equipment. This trend will undoubtedly continue until eventually all
British vehicles have negative ground electrics.
Geo Hahn
Lou Metelko said:
A group 27 (original) size fills the shelf much better than the more common group 24...
Quite so... but the 24 is the one readily available from W-Mart for small money. It doesn't look half bad if stripped of its modern labels and the 3-hole caps replaced with a set of 6 vintage caps.
For the group 24 I use a couple of wood spacers on each side to keep it from sliding around.
T MGB Quick question about something that don't really matter just want to know. MG 9
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
S MGB 1980 MGB quick question MG 2
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR6 Quick TR6 alternator question Triumph 6
M Quick tachometer wiring question on a '65 Spridgets 10
Willie_P Quick question: rear diff TR 3/4 Triumph 6
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
MCNX_BFF Quick catch-up and trailer question Triumph 8
skelly Quick question from a newbie Spridgets 10
PatGalvin Captive nuts?? quick question Triumph 7
JPSmit Quick Spark plug question Spridgets 10
Sarastro Quick dumb transmission question Spridgets 9
T Quick fuel pump question - mounting angle MG 3
T TR4/4A TR4a retrofitting of roll bar - quick question Triumph 1
bigjones HS4 - quick question MG 6
JPSmit Quick HS4 Question MG 2
T don't have my book, quick torque question Triumph 5
JPSmit Quick Transmission question Spridgets 2
L A quick question for you UK/European LBCers Spridgets 0
Jim_Gruber Quick Carb Question Spridgets 16
bigjones Quick alternator question Spridgets 16
livinginthepast Quick question on setting fast idle/balancing carb Spridgets 21
M TR2/3/3A Quick TR3 Question .Trans cover color Triumph 6
D Quick Question C to F Restoration & Tools 4
JPSmit Quick Carb Question Spridgets 2
theleisure quick clutch question Spridgets 10
T Quick 1275 question on a Mini motor Spridgets 2
tosoutherncars HEEELP! Quick soft top question Spridgets 7
JPSmit Quick question #2 Emergency Brake Spridgets 1
Stewart Quick wiring question MG 6
cmacmillan TR6 Quick question on Haynes for TR6... Triumph 3
J TR4/4A Quick TR4A wiring question Triumph 6
jlaird Quick question Spridgets 5
jjbunn Quick Speedo Question Triumph 14
JPSmit Quick Question - rear hub torque Spridgets 4
mlarnoldTR6 Quick question Triumph 2
RickB MGB Quick tire size question - MGB MG 10
JPSmit Very Quick Question - rear oil seal Spridgets 2
P Quick Coil Question. Triumph 3
JPSmit Quick rear brake question Spridgets 56
T A quick silly Crypty question. Triumph 3
Webb Quick Alternator Wiring Question Triumph 3
Trevor Jessie Quick question...really [about line fitting] Spridgets 14
tosoutherncars Quick question - 1500 wiring for coil Spridgets 7
tosoutherncars QUICK QUESTION - manifold bolts Spridgets 3
Sarastro Just a quick, dumb generator asssembly question Spridgets 2
JPSmit Quick Spring Question Spridgets 10
