TR2/3/3A Newbie wrestling with TR3 rear wheel studs
Andrews
I am not an accomplished mechanic, but thought replacing the rear wheel studs on my TR3 would not be too complicated... I don't know why as most things with this car seem more complicated once I get into them due to conflicting information, prior alterations and modifications, my own limitations, rust etc...
The issue is the lugs seem to have been cross threaded on as it took a lot of torque to get them off, and I assume the old studs and lugs are trash... so I bought new lugs and studs and am confused since the studs are not the type to simply be entered from behind the hub and lock into place... They apparently screw in from the front... the Haynes and Triumph shop manuals do not offer much help in removing the old ones without trashing the hub in the process.
Any advice or direction to go for help would be greatly appreciated!
Thank you!
Andrew
TR3driver
Great Pumpkin - R.I.P
It is, unfortunately, not well documented. Apparently the idea was to replace the hubs as a unit rather than individual studs.
Anyway, yes, the rear studs (only) screw in from the face on the solid axle cars. After they are screwed in, the back of the stud is deformed (staked) to keep them from coming out. Once installed, the studs cannot be removed and reused, they have to be replaced every time (tho I'm not sure why you would ever want to remove and reuse them).
To get them out without damage to the hub, IMO it is best to first remove the hub and half shaft from the axle housing (assuming you are working on the later 'Girling' axle). You can leave the brakes and shims in place, but it's best to have a bolt & nut handy to secure them to the axle.
Don't lose the shims, they are important.
Use a Dremel or small die grinder to remove as much of the staked-over part of the stud as possible without cutting into the hub (too much); then unscrew the stud as far as it will go. If it doesn't come out, screw it back in and remove some more metal (the process will have raised the staked portion a bit so you can grind more of it away).
Once the new studs are in place, use a sharp punch and BFH to peen the backs again.
I tried once using ordinary splined studs from FLAPS, but the experiment did not go well. The metal in the TR hubs is very hard, and instead of deforming around the stud splines, it just sheared them off. Better preparation (eg chamfering the holes after drilling them) might have prevented that, but I didn't pursue the project.
bobhustead
To expound on the removal of the shaft and hub as a unit, you will not be able to get the hub off the axle without special tools. I did mine with the axle and hub in place. What a pita.
Bob
A
Andrews
Thank you very much for the quick and thorough replies! Looks like I will have to find a day or two when I have serious time available.
Andrew
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
steveg TR6 Newbie looking for hopup guidance Triumph 15
njunear Newbie - to this forum, that is........ Austin Healey 8
S TR2/3/3A Newbie Triumph 15
L Spitfire Newbie amateur mechanic needs help w/California smog equipment Triumph 6
D aspiring AH newbie: some questions Austin Healey 16
steveg Newbie questions on pulling an engine Austin Healey 19
S MGB Newbie 1978 MGB questions MG 11
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
5 Newbie looking at a '67 Austin FX4 Taxi... Other British Cars 15
T Newbie Bugeye Sprite owner engine advise needed Spridgets 5
A Newbie Bugeye Sprite Mk1 owner looking for some advice Spridgets 49
S MGB-GT Newbie researching MGB GTs MG 28
S General TR Newbie looking for 2+2 Triumphs and other makes Triumph 15
R Hello all and a question for a newbie... Austin Healey 13
Steve P. Newbie with more questions Racing 8
Steve P. Newbie with XJS...opinions wanted Racing 9
B TR2/3/3A Newbie in need of help TR3 Triumph 11
60TR3A Dumb Newbie Question Austin Healey 16
skelly Quick question from a newbie Spridgets 10
Willie_P Newbie HELP: TR 3/4 leaf spring/axle installation Triumph 11
Henson80MGB Newbie w/ low fuel pressure issue MG 11
C TR2/3/3A New member and newbie question on TR3 clutch Triumph 26
A GT6 GT6 Newbie question Triumph 6
stretchit2 HAPPY NEW from a Newbie Austin Healey 3
M Newbie: Just Checking In MG 7
B TR2/3/3A 57 TR3 Newbie...No spark? Basket case Triumph 31
R Newbie with Carb questions... Spridgets 12
R Newbie with carb questions... Austin Healey 11
M Help to the newbie - Diff Whine Austin Healey 16
Reginald Newbie from West Coast, NY, & Caribbean. '80 LE MG 7
M Newbie still puzzeled about flooding carb MG 6
G T-Series Newbie '51 MGTD MG 2
T Newbie Midget owner Spridgets 28
T TR2/3/3A TR2 question from a newbie Triumph 6
T Newbie SU Carb Rebuild & Restoration Question Triumph 31
D NEWBIE Triumph 38
jvandyke newbie pulls motor radiator bolts? Spridgets 18
EastBoundJoe Welding newbie Spridgets 39
sobamaflyer Newbie - please help with first drive impressions Spridgets 19
crya HELP! Newbie needs to know how to remove HUBS. Austin Healey 2
Mg_Bizzle Lowering blocks and front sus [newbie fitting q's] MG 20
Lukeee Newbie! Spridgets 5
T Newbie question about hoodstick cover installation Triumph 10
J Hello. Newbie here. Spridgets 35
J jack's newbie question of the day-increasing comp Triumph 22
69sprite Newbie Spridgets 7
M Newbie question about charging system Spridgets 9
