Girling brakes on a Chrysler?
PhilW
I'm not sure this is the correct forum, but here goes. In some box lots of British car parts I bought a while ago, there are some boxes of Girling brake shoes in Chrysler labled boxes. I think the dates are around the early 70's. They're small, probably for a 13" drum. I doubt a Sunbeam Tiger, they must of had larger wheels, or at least disc brakes. (I think Chrysler owned them for the last year.) Any help or sites will be appreciated.
Thanks,
Phil.
Steve
Platinum
Hmmmm, I am guessing that these might be for the Hillman Avenger/Plymouth Cricket. Might be a good place to start at any rate. Didn't the Alpine have rear drums as well?
AngliaGT
Steve,
I think you're right - Plymouth Cricket,or Simca.
When's the last time anyone saw one of those?
I did see an Audi Fox estate the other day - weird!
- Doug
P
PhilW
Hmmmm....
Now I have to find someone that needs a few sets of brake shoes for their fleet of Crickets. At maybe a dollar a shoe, I have lots of room to negotiate. More likely, nine cents a pound at the scrapper.
Phil.
P
PhilW
A friend of mine emailed me to say that one set of Girling shoes (along with a set of linings) are to a '71 Plymouth Cricket (64937136).
The other 2 shoes (1 wheel) and 4 linings for same, are Mintex but only have Chrysler numbers - 29152X (4 linings),23063 and 23070 (2 shoes). Linings are similar to above but drilled a bit different and different lengths. As if the slogan for the new, '72 was "Now, with 15% more braking ability".
I'll be at the Hereshey swap meet. There's bound to be at least one Cricket owner among 200K car people.
Phil.
bugimike
Simcas were also sold under the Chrysler label. Not sure if they had Girlings though!
sunbeammadd
Don't be too quick to dismiss the earlier Rootes cars. I've seen plenty of parts for these in Chrysler boxes. Could be Tiger - Tigers had rear drums - Alpine, Rapier, Minx, Imp.......
R TR2/3/3A Girling Rear Brakes Triumph 9
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
A Wanted Girling Axle for TR2 Triumph Classifieds 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
algot1901 Girling Brake adjustment Other British Cars 2
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
Lin Girling Master Cylinders Austin Healey 5
S General Tech Standard for the Girling Bubble Flare Triumph 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
S T-Series girling shocks MG 0
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
R Girling vs other wheel cylinders Austin Healey 10
2 TR2/3/3A Girling axle disassembly for shipment Triumph 6
H Problems with Girling master cylinder Austin Healey 8
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
K TR2/3/3A Girling Clutch MC Mystery? Triumph 2
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
D Girling replacement booster Jaguar 0
K The Girling Company? Triumph 5
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
HerronScott Lucas and Girling Triumph 3
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
H Rebuilding Girling 16P Triumph 5
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
BOBBYR Girling brake booster Austin Healey 5
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
Z Girling/Armstrong lever arm shocks Spridgets 2
T Lucas girling brake pads Triumph 2
davelgee Girling MK2a vacuum servos? Other Cars 31
Scott_Hower Girling Red Rubber Grease? MG 1
Adventurer_96 Girling Brake Question - UPDATE 2/12 Restoration & Tools 34
