Re: Girling Brake Question
It's amazing what you can find out when you take a wheel off. I removed the right front wheel yesterday, which is where the largest leak was coming from. In fact, when I checked out the garage the other day I saw a very large pool under the right front, and a few drops coming off the rear wheels, and the master cylinder was empty.
When I removed the wheel, I could see a large amount of fluid was leaking off of the caliper. When I squeezed the dust covers on the pistons I found that LOTS of fluid came out of there. I decided to remove the pads, and then the caliper entirely.
On a side note, yesterday's foray into the world of Sunbeam brake repair was very important to me. Prior to that, I wanted nothing to do with brakes, but seeing how easy these systems are to analyze, I really got a huge confidence boost that I'd be able to fix most anything that came along in this car.
Back to the story. After removing the caliper, I got some compressed air and blew it into the caliper to get the pistons out. One came out, and immediately I found the problem. It appears that the seal on the inside of the caliper was gouged out. In fact, when the piston came out, a chunk of the rubber came out with it. I didn't remove the other piston, but I'm guessing that's the same case on that side as well.
Interestingly enough, the left front brake doesn't leak at all, which is a good sign. I plan on ordering the seals this week and replacing them.
Also, I'm going to keep using the Valvoline synthetic fluid as it seems to be a little less caustic than the Castrol stuff.
Next week, I hope to fix the front brake and begin to analzye the rear brake - the garage where I was working was closing so I had to call it quits before getting on to the rear brakes.
