100-4 brake / clutch pedal seals not available
LuckyLuke
Since the rubber seals that seal the brake and clutch pedal to the Body are not available anymore….. I like to see if someone had success to home making them out of something else.
Dave Russell
Yoda - R.I.P
I assume that you are referring to the "draft excluder" rubber bits that fit over the pedal stalks & seal the underside to the floor board. The metal backing plates should still be on the stalks.
I've had good luck cutting 3/8" high density foam to shape, slitting the bottom edge, slipping the foam over the stalk, & gluing the foam to the metal backing plate.
LuckyLuke
LuckyLuke
Thanks, the draft excluder is what I need. What kind of rubber foam did you use? Source ?
Rolf
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
Marvin Gruber 100/6 Brake Upgrade Austin Healey 5
L Front Brake 100/6 Austin Healey 1
L 100/6 BN4 Brake fluid Austin Healey 17
B Power Brake Servo for a 100 Austin Healey 3
O 57 100-6 Disk Brake Upgrade kit Austin Healey 9
J Drum brake instructions for 100/6 or 3000 Austin Healey 4
C 100 Drum Brake Keep or upgrade to disc? Austin Healey 9
B Early 100 brake parts needed Austin Healey 1
H 100/6 Brake Drums Austin Healey 1
C 100-6 Resto-Mod Nasty-Boy Brake Upgrade - Help... Austin Healey 2
H 100/6 Brake drums Austin Healey 1
356roadster brake drums for early 100 bn1: where to buy? Austin Healey 16
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 6
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 7
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
