TR6 Clutch pedal click noise
pdplot
Clutch works perfectly but pedal now occasionally makes a loud CLICK when pushed even an inch or so. Perhaps every 3rd time and sometimes just a soft click just to let me know its still there.I squirted some WD40 up there but no change. I can also feel it in the pedal. Any ideas?
M_Pied_Lourd
First thing I’d check is the Clevis pin that holds the pedal to the rod in the footwell.
Cheers,
Tush
P
pdplot
I'd have to use a mirror since I can no longer lay under or on top of a car. I'll also have to figure out what I'm looking for. I'll check my catalogs to see what's up there.
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T Clutch Pedal Engagement Point Austin Healey 1
Jeepster Clutch Pedal Position Austin Healey 4
C BN1 Clutch Pedal Rattle Austin Healey 2
G TR6 Binding Clutch Pedal Triumph 5
D TR2/3/3A clutch/brake pedal question Triumph 4
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
S TR2/3/3A clutch pedal connection hole Triumph 9
P TR6 Clutch pedal noise Triumph 2
B TR2/3/3A Where on the clutch pedal? Triumph 4
tomshobby TR6 power assist for clutch pedal Triumph 12
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
B TR6 TR6 clutch pedal height Triumph 2
Lukens TR2/3/3A Occasional soft clutch pedal? Triumph 2
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
aeronca65t Clutch pedal problem- 1275 race car Spridgets 12
PatGalvin TR2/3/3A Brake and Clutch pedal to MC adjustments? Triumph 4
Patrick67BJ8 Clutch Pedal Won't Go All The Way To The Floor Austin Healey 20
K TR2/3/3A Replacing Clutch Pedal Triumph 8
K TR2/3/3A Brake and Clutch MC pushrod/pedal bolt stops? Triumph 2
B argh,,clutch pedal to floor Spridgets 6
Scotsman Adjusting clutch pedal travel Triumph 2
bighealeysource Feel vibration when depressing clutch pedal on BN2 Austin Healey 4
T TR2/3/3A TR3a Clutch Pedal Return Triumph 2
T TR4/4A Anyone have a spare TR4a clutch pedal? Triumph 3
aeronca65t Common problem-clutch pedal Spridgets 2
B Clutch pedal no fluid? 2 -3 years of sitting... Spridgets 30
W Clutch Pedal Feel Austin Healey 3
A T-Series Clutch pedal slow to rise MG 11
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
F RHD Clutch Pedal Jaguar 1
W Clutch Pedal Jaguar 8
CJD Brake/Clutch pedal adjustment Triumph 29
RJS TR4/4A TR4A Heavy Clutch Pedal Triumph 2
M Clutch pedal noise Triumph 16
pipercollins Part Wanted: Clutch Pedal Triumph 2
S Floppy clutch pedal Triumph 5
1 T-Series Clutch pedal travel and point of engagement MG 5
J Brake/clutch pedal frozen Triumph 18
dklawson Rhetorical Question/Comment - Use of Clutch Pedal? Triumph 29
M Bugeye clutch pedal sticking Spridgets 2
P weird thing with midget clutch pedal Spridgets 3
D clutch pedal Spridgets 4
DMShuman TR5/TR250 TR 250 issue with Clutch pedal Triumph 4
S BN1 clutch and brake pedal bracket Austin Healey 3
Lin clutch pedal Spridgets 2
tomshobby A way to lube the clutch pedal pivot. Triumph 1
Brosky TR6 TR6 V-8 Automatic, with optional clutch pedal Triumph 9
G TR6 Are you happy with your TR6 clutch pedal play? Triumph 28
