BN2 clutch pedal and exhaust downpipe
349A
My new to me BN2 has an odd issue, when the clutch is fully depressed, the pedal arm hits the exhaust downpipe. It makes for an interesting musical instrument at idle tap tap tappity tap. The downpipe is stock. I notice Moss mentions this as a possibility in their listing for a stainless exhaust downpipe with or without a stock downpipe. Is this truly normal or am I missing a pedal stop? Thanks!
Jonathan
roscoe
I'm returning from overseas so I can't go to the barn and look at my car but I do recall a clearance issue but cant remember what I did when I got to that during my rebuild. If nobody answers you before then, when I recover from jet lag I'll take a look and let you know. Might it have to do with the direction a bolt was installed? Often a bolt head will have clearance where the nut side will protrude further so as to not have clearance. Have you looked at it from underneath?
Michael Oritt
It's a close fit at best. Is the stabilizing bracket between engine ans pipe in place?
349A
Thanks Jon and Michael. I’ve spent some time underneath and all looks like the factory diagram from what I can tell. Having never been under another 100, I don’t have a reference besides the drawing.
What does the stabilizing bracket look like and where does it mount?
The car is out of a five year Healey Werks restoration by the PO so its pretty thoroughly done. Basically ever nut and bolt is restored so I’d be mildly surprised if something was missing. Its definitely possible. Downpipe is stock as is the whole exhaust.
Jonathan
Michael Oritt
Look at the exhaust page in the Moss catalogue. it is a piece of metal that mounts between and to the block and the exhaust, designed to stabilize the latter.
Michael Oritt
Yes, that's the piece. It is often missing.
My clutch pedal just hits the downpipe at full travel, and I do have the support bracket (it doesn't change the location of the downpipe). I've been told some cars, at least, had the issue from the factory.
349A
Interesting, Bob. I wonder why only some. Same with mine, when really pushing it all the way down, it hits the downpipe. When the car is cold and idling a little low, the lope causes it to rattle against the pedal.
I’m considering changing to headers anyway, I wonder if that will solve the problem or make it worse. Looking into the DW 100M setup or the Cape International stainless setup.
Jonathan
Well, I kind of hedged a little; I heard they all had the problem but, somewhere out there somebody doesn't and I would have been technically incorrect. I've considered getting a period-style header, as my car is a 100M, but it would have been as much to eliminate the annoying 'pedal knock' as for any HP improvement (I think driving these cars much over 3,500RPM is a risk anyway, as crank fractures are also a known problem). I've just gotten in the habit of not getting the last inch or so out of the clutch pedal; in fact, since the problem is endimic maybe a little spacer on the backside of the pedal might be a worthwhile bandaid*.
* Edit: I've read--in my Mustangs' owners manuals IIRC--something to the effect that 'the clutch pedal needs to go all the way down.' No explanation given but, obviously, if your clutch isn't fully disengaged you'll grind your gears and possibly damage something, but the clutch should be fully released before you floor the pedal (probably no more than, say 3/4 of travel at most). Anyone know the reason for this warning?
349A
Bob- good points about RPM and cranks. I tend to only get up near redline for brief periods when the mood strikes. I normally shift around 3500-3800. While I don’t expect much in the way of HP with a header, they sure sounded nice. Sound/sensation a big part of the joy of vintage cars. Not to mention how pretty they can be. I’m hopeful a header might also give the small extra clearance, I suppose that would be nearly impossible to know unless one installed one.
Clutch all the way in- I was always taught to press it to the floor. I’m unsure exactly why. I would assume if its fully engaged, its fully engaged!
Jonathan
349A
Thank, Bob. I have read that at least twice. It seems the fatigue/breakage issue becomes more and more of a threat if one keeps the RPM’s up often. Its accumulative, a ticking time bomb with no reset button. Of course I have no idea how the car was driven for the first 70,000 miles. Hopefully gently.
Jonathan
bighealeysource Feel vibration when depressing clutch pedal on BN2 Austin Healey 4
B Ball Bearing-type Clutch Release Bearing for BN2 - Availability ??? Austin Healey 2
F BN1/BN2 Clutch linkage Austin Healey 4
W BN2 clutch cover or pressure plate question Austin Healey 2
Thomas591 Clutch relaese bearing BN2 - BN6 Austin Healey 0
A BN2 Chassis Alignment Austin Healey 8
T 100 BN2 Possible Ignition Issue Austin Healey 7
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
H BN7 and BN2 Lengths Austin Healey 3
Gundog61 BN2 Brake Drums Austin Healey 5
bighealeysource BN2 Master Cylinder Austin Healey 91
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
MikeAH100M BN2 Tight Steering Austin Healey 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Gundog61 BN2 Steering Box Leak Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
Guido36 9k-Mile BN2 at Auction Austin Healey 13
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
Guido36 BN1/BN2 Sidescreens Austin Healey 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
J BN2 Shift Lever Bushing Replacement Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
J 100 bn1/bn2 id Austin Healey 26
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
C Wanted 100/4 BN2 1956 Le Mans side windows Austin Healey Classifieds 0
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
aero3113 BN2 Front Chassis Rail Austin Healey 6
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
A BN2 Boot Lid Austin Healey 4
P BN2 new wood steering wheel install Austin Healey 5
W Gear Lever Boot for BN2 Austin Healey 5
J BN2 shift bushing replacement Austin Healey 5
wangdango BN2 wheel cyclinders/replacement Austin Healey 1
