BN1/BN2 Clutch linkage
Fury5
Friends,
Can anyone tell me the correct (stock) length of the adjustable connecting rod in the clutch linkage? I am wondering if the rod on the car now (it is new and was installed by a restorer) is too short. I have been trying to adjust the free play in my clutch pedal. It was at about two inches (which made shifting a bit dodgy). I managed to bring the free play down to about 1.25 inches but have run out of room for further adjustments because the rear adjusting nut is now all the way back at the end of the rod. The car is shifting fine now. Maybe I should leave well enough alone, but I think the manual says free play in the pedal should only be about 11/16 of an inch.
BTW, the car is a BN1 but at some point before I bought it someone put in a BN2 transmission. Don't know if that makes any difference.
Many thanks.
Richard
glemon
I have to admit the clutch release on my 100 worked fine the whole time I owned it, so I didn't have to mess with it except for when I pulled the tranny or motor, which fortunately was only once each. But with all mechanisms like this the various components in the linkage wear and cause further play. It looks like some of the parts including the lever on the clutch and the pedal assembly, depending upon where the wear occurs the minute wear can be exaggerated in overall clutch pedal play. I would suspect that is you culprit as much as the new part. As I mentioned mine worked fine for my 10 years of ownership, never measured the actual play. You can either use it as is or try to track down the extra play, or if none see what Moss will do about the part if it is in fact the problem (and I am not dismissing that as a possible problem, it certainly happens).
F
Fury5
Thanks. I will check for play in the other parts of the linkage. You now have me suspicious that the lever that attaches to the operating shaft may have some "extra" play in it. But I'm still curious what the stock linkage length is. I am toying with the idea of "upgrading" to something like the following (assuming I can get the right length) which looks like a superior design: https://www.jbfab.net/cgi-bin/miva?...reen=CTGY&Store_Code=JCFCS&Category_Code=Link
Cheers.
TodE
Fury5,
You might want to look at "tomsimport.com" it has all the adjustments along with grease fittings so you reduce the wear. I put one on my BN-1 with a 4 speed transmission. The car is not on the road yet, but it appears to be much better than the factory setup.
Good Luck,
Tod
pan
Hi Fury 5,
You should have plenty of length on the rod to play with. There should only be eleven sixteenths of an inch free play in the pedal. Could the operating lever be installed back to front? The hole that engages with the operating shaft is not in line with the lever but rotated some degrees. Also the throw-out bearing (carbon thrust or release bearing, not sure of American terninology) could be near the end of its life.
The pivot shaft can also deteriorate, causing lack of useful travel.
Guido36 BN1/BN2 Sidescreens Austin Healey 0
J 100 bn1/bn2 id Austin Healey 26
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
F BN1 vs Bn2 gear box Austin Healey 23
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
roscoe BN1/BN2 Alternator Conversion Austin Healey 7
A Sidecurtains for BN1 OR BN2 Austin Healey 1
T BN1 / BN2 Top Installation Austin Healey 3
R BN1 & BN2 Engine # Plate Finish Austin Healey 25
Vineyarder BN1 BN2 Transmission Question, Returning member Austin Healey 0
F BN1 or BN2 for sale in Europe? Austin Healey 3
ShawnC_at_Moss BN1, BN2 Carb Bodies with shafts Austin Healey 0
bighealeysource Anyone ever mount a side exhaust on a BN1 or BN2 Austin Healey 16
T BN1 / BN2 Horns Austin Healey 2
Frankenhealey BN1 or BN2 Hood? Austin Healey 3
W Rear axle oil seals for BN1 or BN2 Austin Healey 0
T BN1 3 Speed to BN2 4 Speed Austin Healey 15
timbn2 are these from a BN1/BN2 by chance...? Austin Healey 20
AH100M BN1 and BN2 two-tone Austin Healey 2
roscoe BN1/BN2 windshield Austin Healey 1
1 100-4 BN1/BN2 Drivetrain wanted Austin Healey 0
P BN1 / BN2 with a serious identity problem Austin Healey 1
A bn1-bn2 recognition Austin Healey 9
jtb55 Conversion of front brakes from BN1 to Bn2 Austin Healey 9
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
M BN1 Loss of Power Austin Healey 21
