Conversion of front brakes from BN1 to Bn2
jtb55
Member
I run my 100 in VSCCA race events. It curently has BN1 front drums and I want to convert to the wider BN2 drums. Any thoughts on what this entails ? thanks jtb
Keoke
JTB, You might give Bruce Phillips a call at Healey Surgeons I am sure he can answer your question.---Keoke
healeys4me
JTB, you may also want to consider a disk brake conversion. Cape International has a kit I installed for a friend, made a great improvement in stopping power. A bit $$$ but the owner was happy with the cost / performance ratio.
Keoke
You are certainly right about the Cape products being pricey,but they sure have some good hardware upgrades for the Healey cars.I have ordered the top trunion bearings for my cars and will not regret getting rid of the Bronze and brite washer bit.---Keoke /ubbthreads/images/graemlins/driving.gif
jtb55
jtb55
Member
Thanks for the input. As the VSCCA does not permit discs while it is I agree the best upgrade, Has anyone gone done a Bn 1 to BN 2 conversion. thanks jtb
jtb55
jtb55
Member
A fellow VSCCA member has provided spindles,backing plates and shoes and I have sourced the bearings, distance pieces, shims etc from the Healy Surgeons and will be making the conversion this spring. thanks all jtb
Keoke
VSCCA Does not permit disks; /ubbthreads/images/graemlins/shocked.gif
Hey JTB55, Aren't the Daimler SP250 cars running in VSCCA? They have Disk brakes!. You need good brakes so you can brake late in the corners.---Keoke /ubbthreads/images/graemlins/thumbsup.gif
jtb55
jtb55
Member
VSCCA has rules for each type of car which are administered by the Car Classification Committee. I checked with the committee and for the AH 100 discs are not permitted. It may be different or the sp250. thanks jtb
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
I Bug eye front disc brake conversion. Spridgets 5
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
R TR2/3/3A Front Brake Conversion Triumph 5
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
D DIY - Front tube shock conversion Spridgets 33
B Front Disk Conversion Spridgets 3
richberman pictures of front disk conversion? Austin Healey 31
M Front Big Brake Conversion Spridgets 20
MadRiver Front tube shock conversion? Austin Healey 2
M BN4 prob with disc brake conversion[front] Austin Healey 2
R front brake conversion Austin Healey 13
AndreL TR6 Conversion to electric fuel pump Triumph 11
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
zoohow TR6 Carburetor Conversion kit Triumph 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
R Smitty Toyota Conversion Angle Drive Austin Healey 16
P Positive to Negative Conversion Austin Healey 1
P Pos to Neg Conversion Austin Healey 1
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
D transmission conversion Other British Cars 1
W TR2/3/3A Wire Wheel Conversion Triumph 5
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
petnatcar Breather Hose Conversion Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye disk brake conversion Spridgets 10
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
Walter74 Throttle Cable Conversion Austin Healey 6
PAUL161 T-Series Dynamator Alternator conversion. MG 23
M Dynamo to "Dynamator" Conversion Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
H Shock absorber conversion Austin Healey 3
S MGB MGB engine conversion MG 27
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
J TR6 Moss HS6 SU conversion kit question Triumph 4
roscoe 5 speed conversion question Austin Healey 9
maxwedge5281 bought back my first nasty boy conversion!! Austin Healey 6
steveg Cost of V8 conversion Austin Healey 34
