Just installed LED headlights in BN2
Martinld123
Bronze
I just installed BN2 Headlights from Moss Motors. They seem to work great but wish I knew how much less amps they draw than the original and also I am not sure of best way to align headlights. Any ideas? Thanks Marty
John Turney
Here's a comparison from https://www.aa1car.com/library/electrical_amp_loads.htm: (Sorry about the bold; it came with the copy & paste.)
Headlights (halogen low beam) - 8 to 9 amps per pair
Headlights (halogen high beam) - 9 to 10 amps per pair
Headlights (halogen high and low beams combined) - 17 to 19 amps
Headlights (High Energy Discharge) - 12 to 14 amps during initial start, 7 to 8 amps once bulbs are hot
Headlights (LED) - 0.6 to 1 amps per bulb
Here's info on alignment: https://www.popularmechanics.com/cars/a257/how-to-adjust-lights/
Martinld123
Martinld123
Bronze
Thanks your information was a big help. I will try to get out to the garage and check beam aim tonight. Thanks Again, Marty
jimmyr
Member
Moss seems to only list halogen 7 inch headlamps, and I seem not able to find the LED ones anywhere. LED types would be great on the generator equipped Healeys. Possibly the positive ground systems may not work on the standard LED lamps?
John Turney
The Moss conversions (choice of with or without headlamps) is here: https://mossmotors.com/led-conversion-kits-for-7-h4-headlamps. According to the descrip[tion, they are dual polarity.
RAC68
Hi Marty,
A while back, I installed Halogen sealed beams along with an alternator, some upgraded wiring and relays that, in combination, provide plenty of power and light for safe night driving. However, it was not long before many of the on-coming cars had high output lighting with sharp cut-offs and my Healey's driving position seemed to put me under the cut-off beam and in line with the brightest portion of their on-coming beam. As a result, driving at night is less safe than ever and I stopped driving my Healey after dark.
I can agree that LED head lamps are more power efficient than standard original sealed beams and do provide far greater road light. However, today, since I refrain from driving my Healey at night, even my modest expenditure of $13 per Halogen sealed beam along with the $85 in alternator and odds and ends (designed the alternator mounting) present less value and, at my present level of use, will last forever.
So, not to be negative but, I am anxious to learn what benefits you expect from your lighting upgrade?
Ray(64BJ8P1)
Keoke
Headlights
LED - 0.6 to 1 amps per bulb----WOW: --Thanks John
Your dynamo gonna just love you.
N Ray!
Just think now you can drive your Healey, head lights on in the day time just like the newer car folks do-----LOL
RAC68
Hi Keoke,
You are right. I do drive with the head lights on during the day and its the only time the lights are used by me. However, my wife doesn't have the problem and can drive the Healey at night. They do work well.
Ray(64BJ8P1)
Martinld123
Martinld123
Bronze
Sorry I have been gone for a few weeks. They are in front of Moss catalog page A5 for $169. Look around I have seen them for less but different name. Lots of them on Internet but need to do homework so as to get the best ones. Moss units work great with my generator. Run during day for safety. Best thing I have put on my car in years. Marty
Marty,
Is your car still (righteous) positive ground?
Bob
Martinld123
Martinld123
Bronze
Sorry I was gone for couple weeks. I now run like you said during day with lights on for safety. I think my generator loves them. There seems like many types out there to chose from so need to do homework. These are in front of Moss catalog on page A5. Marty
Martinld123
Martinld123
Bronze
No, negative ground but these LED head lights will work with positive ground also. From Moss name is Stella Lux led conversion at $169 on page A5 in catolag. Marty
Martinld123
Martinld123
Bronze
My big reason for using low amp LED was so I could use with my generator during day and night. I want to be seen during the day. Very low amp draw.
Hi Marty,
Ray(64BJ8P1)
RAC68
Hi Marty,
That is an excellent reason for doing your conversion. Although I would have preferred keeping the generator, I had issues also with the voltage regulator and the alternator conversion provided excellent power for my lights and sound system as well as eliminated the need for an external working voltage regulator (VR incorporated in the Alternator. The external VR is still installed but gutted and only used as a convenient wiring connection point for power distribution).
If I had a good voltage regulator and the LED headlights were as good then as today, I may also have opted to keep the generator and go LEDs. Not sorry I went alternator and do enjoy driving with the Beach Boys harmonizing to my exhaust note.
All the best,
Ray(64BJ8P1)
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Can a TF engine be installed in a TD body? MG 7
J Restoration Progress - Boot Installed Austin Healey 1
nichola TR6 New harness installed but have a purple problem Triumph 12
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Zitch For Sale OE Under Dash Speaker refinished new speaker installed Triumph Classifieds 0
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
Jim_Gruber Thoughts on driving Bugsy with the hardtop installed. Spridgets 32
aero3113 Wire Wheels and Top installed Austin Healey 17
K TR4/4A Running the motor witout the gearbox installed? Triumph 3
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
S Seat Belts Installed This Weekend Austin Healey 43
T TR2/3/3A Miata seats installed in my TR3A Triumph 14
DerekJ Another dealer installed 100 Le Mans!! Austin Healey 17
J TR2/3/3A Installing body to chassis with engine installed Triumph 7
F TR2/3/3A I just installed a rebuilt C39 Generator on my TR3 Triumph 11
Tinkerman TR2/3/3A It's installed, It fits, It looks great, I'm excited!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Triumph 8
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
DanLewis Anyone ever installed a Mercedes hood vent on a Bugeye? Spridgets 5
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
K TR6 Flywheel installed without the locating dowels? Triumph 5
E Got the side exit exhaust installed on my Austin Healey-Video Austin Healey 21
Darrell_Walker Wedge Rimmer's front rally spoiler installed on my TR8 Triumph 22
2wrench New Solenoid Installed on J Overdrive and now no juice to the Solenoid. Triumph 3
Gliderman8 Fuel Pump Installed Triumph 0
Brinkerhoff TR6 TR6 OD gearbox installed in TR3 ? Triumph 11
Stinger TR4/4A TR4A Dealer Installed Mirrors Triumph 5
B TR2/3/3A Rad installed = TR3A no run Triumph 8
Russ Austin New Facia Installed Triumph 5
Stinger TR4/4A TR4A Padded Dash Installed Weatherstrip Question Triumph 7
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
drooartz Installed my new Moto-Lita today MG 12
bugedd Just installed springs Spridgets 5
B BJ7 hood installed Austin Healey 6
G Kingpin bushings installed for $80? Spridgets 6
JohnnyO Finally got my radio installed Spridgets 11
philman Wedge Miata Seat installed in a TR7V8 Triumph 10
Nelson Windshield seal installed Spridgets 1
RickB Installed spin on adapter yesterday - 948 motor Spridgets 5
Brosky Miata seats 98% INSTALLED! Triumph 16
hondo402000 TR6 Fan Shroud Installed on TR6 Triumph 8
W Got the fuel pump installed today Spridgets 7
drooartz Progress: fuel pump installed Spridgets 2
Tinkerman Body Installed Today, YEAAAA! Triumph 8
zschicago Installed Dennis Welch brake kit Austin Healey 5
J BJ8- How is the chrome door top molding installed? Austin Healey 11
martx-5 Installed My New Steering Wheel Triumph 7
M TR2/3/3A TR3 Battery Box Installed Triumph 23
Luke_Healey Installed master cylinder, how to get pressure? Spridgets 7
