TR6 Fan Shroud Installed on TR6
hondo402000
Well I finished the Fan shroud and installed it on Saturday, Looks like it will work well, Amazing, one of the few projects that I made and didnt have to do a lot of fitting up, grindind and rework to get it installed, Fits like a glove, Now if I get the car finished and back together and drive it to see if it works
Hondo
hondo402000
hondo402000
I do have a front fan shroud, currently its out of the car as the paint job is still going on but soon to finish, as noted by all the sanding dust. I got the bonnet hinges and boot hinges painted this weekend too.
Hondo
T
Tinster
Hondo- nice job.
Now a stupid question. I've reconstructed a 1969 TR6
without ever seeing a real TR6 up close for comparison.
I know many, many parts and components were missing from
my car. Probably lots more I don't know about.
My car had a busted radiator with no shroud in front
or behind. When I replaced the radiator, I fabricated
a shroud for in front. My fan is red with many blades
more than yours. I think my fan might be larger in diameter
than yours as well.
Now the stupid question-
? What is the purpose of the shroud between the radiator
rear side and the fan bladed? My engine NEVER overheats
and I live in the tropics.
Best regards
dale todd
70herald
Best regards
dale todd
No such thing as a stupid question!
The shroud improves the efficiency of the fan. otherwise, allot of the air that the fan circulates just goes from the back of the fan and then circles around to the front of the fan again without stopping by to visit the radiator.
The front shroud is there to make sure that air going through the radiator is cool air from outside the car.
swift6
Dale, as far as the differences in fans... The early TR6s had smaller, yellow fans. Later TR6s had larger 13 blade red fans. If your TR6 has the later fan, it was effectively upgraded to a larger fan capable of moving more air than the standard early fan. If your not overheating, the extra shroud around the fan won't do much, and what it helps with would only be noticed at idle. It may increase the efficiency of your cooling system slightly, but it would be a bunch of effort for very little, and in your case unnecessary gain. If you have the shroud forward of the radiator, the amount of air it directs through the radiator at speeds more than 25-30mph is more than the fan can pull through anyway. So over 30mph, the size of the fan and the shroud around the fan don't make much difference.
Brosky
I think that it would be hard to retro fit the bigger fan like this one is done. It's so big that the material left to surround it would be minimal and hard to form.
Nice job on this one though. I'll bet it solves any issues that Hondo may have.
hondo402000
hondo402000
Dale
yes the shroud in back of the radiator is one I made with fiberglass and a form, it is not a standard equipment item, I belive swift6 explains it well, I do have a slight overheating issue during the summer when stopped at a light so I am hoping this will help by pulling more cool air thru the radiator at a stoplight.
Hondo
DNK
There's a red fan on eBay where the guy wants 600+ for it.
R TR6 fan shroud replacement Triumph 5
N Bumper bracket and fan shroud color Austin Healey 5
B Fan Blade Shroud Austin Healey 5
svtmikey GT6 Fan shroud help Triumph 9
busybrit Color of BJ8 fan shroud Austin Healey 14
S Red Fan Shroud BJ8 Austin Healey 2
H norman nock fan shroud Austin Healey 22
Keith_M Fan Shroud Austin Healey 26
Patrick67BJ8 Kilmartin Radiator Fan Shroud Austin Healey 4
M Electric fan and shroud for a 100 4 Austin Healey 3
hondo402000 TR6 TR6 fan shroud, home made Triumph 7
T Tips on removing fan shroud? Spridgets 6
O Fan shroud Red Austin Healey 8
K radiator fan shroud Triumph 21
Stewart Moss plastic fan shroud MG 2
7 New fan shroud - great results Triumph 1
7 Fan shroud Triumph 21
A Fan shroud attachment - how? Austin Healey 10
Dave Richards Fan Shroud Color BJ8 Austin Healey 8
P Radiator Fan Shroud [aka finger protector] Austin Healey 1
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
F Revotec Fan Austin Healey 2
S Installing a Radiator Fan Austin Healey 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
RJS TR4/4A Radiator Fan Shround Triumph 3
KVH General Tech Fan Not Backward — Balancers Triumph 5
A Spitfire Install fan Triumph 1
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
R six bladed fan - bugeye Spridgets 2
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
Lin Fan belt for 1275 with alternator Spridgets 4
Tr3aguy TR2/3/3A Tropical Fan Triumph 19
G Thermo Fan Sensor Austin Healey 5
J BJ8 Radiator Fan Austin Healey 12
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
D Spitfire Electric fan Triumph 3
Zitch For Sale 8 Blade yellow Fan for triumph Triumph Classifieds 2
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
