Revotec Fan
bdcvg
Yes I tried one. It's front mount so no it didn't work. It would not pinwheel so actually blocked the air flow. I think there is enough room to fab brackets and move the radiator forward to accommodate converting it to a puller. The electronics were good and the fan itself was nice. I went the easy way and used aluminum rad with Texas cooler. Now in the fall I run a tad cool.
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
B Revotec fan kit Austin Healey 4
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
S Installing a Radiator Fan Austin Healey 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
RJS TR4/4A Radiator Fan Shround Triumph 3
KVH General Tech Fan Not Backward — Balancers Triumph 5
A Spitfire Install fan Triumph 1
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
R six bladed fan - bugeye Spridgets 2
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
Lin Fan belt for 1275 with alternator Spridgets 4
Tr3aguy TR2/3/3A Tropical Fan Triumph 19
G Thermo Fan Sensor Austin Healey 5
R TR6 fan shroud replacement Triumph 5
J BJ8 Radiator Fan Austin Healey 12
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
D Spitfire Electric fan Triumph 3
Zitch For Sale 8 Blade yellow Fan for triumph Triumph Classifieds 2
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
T BJ8 Fan Belt Change Austin Healey 7
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
S Heater and fan control replacement - any advice? Austin Healey 9
B Fan Blade Failure Austin Healey 6
D Fan Blade Austin Healey 11
B TR6 TR6 Fan Belt Triumph 4
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
FlyingCat Spitfire Electric Radiator Fan Triumph 10
N Bumper bracket and fan shroud color Austin Healey 5
FlyingCat Spitfire Radiator and fan Triumph 5
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
TomMull TR2/3/3A Tropical fan, I wonder what I bought?? Triumph 2
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
I Correct orientation of the fan blades. Austin Healey 13
TomMull Wanted Tropical fan for TR3 Triumph Classifieds 8
N Electric fan opinions???? Spridgets 2
