BJ8 Fan Belt Change
tomnanney
Changing my fan belt and have not done this is a while. Looks like I need to remove the nut (starting crank nut) on the end of the lower pulley to get the fan belt off.? Any other way to do it.
thanks
vette
Re: fan belt change on BJ8
I don’t believe you need to remove that nut. I have never needed to. But it is a PITA to get the belt past the pulley and crossmember. You squeeze it thru by rolling the belt and turning the crank. Watch out for the little pink thingies ( fingers) to not get pinched.
T
tomnanney
Thanks for the input. That's what it looked like to me also, but I was just hoping someone had a trick to getting off.! It is a bugger! Also changed the water pump which was no fun either!!
John Turney
Getting the old belt off is easy - just cut it. Getting a new one on is the hard part.
steveg
In order to remove the crank nut, you'd have to remove the radiator, loosen the motor mounts and jack up the engine enough to get the belt off anyway.
BJ8 questions: is it the 1/2" belt? Does anyone use those or have they all been converted back to 3/8" belts?
Will the 1/2" belt fit between the crank pulley and crossmember?
Only BN4s and BN6s have the 3/8" belt (according to Moss, anyway). Changing belt size would require replacing all pulleys, and the 1/2" belt should be stronger and more durable anyway (possible why the 3/8" was superseded). IIRC, I've been able to R&R my BJ8's belt, but it requires twisting and pulling and potentially damaging the belt. Still, easier than pulling the crank pulley nut.
I was incorrect--thanks, Steve--only the later BJ8s have the half-inch belt. OP didn't specify earlier or later BJ8, I think a 3/8" belt wouldn't be much trouble.
BJ8Healeys
My BJ8 had a 1/2" belt, but when I changed the crank damper to the Pro/Race unit I had to change it to a 3/8" belt. I had to change the water pump pulley to 3/8" also, but not for the alternator. Why? Because the alternator already had a pulley for a 3/8" belt and I had been using it with the 1/2" belt for 20 years without noticing it!
I was always able to get the 1/2" belt off between the pulley and cross-member by judicious twisting and tugging, but even that wasn't easy.
S bj8 fan belt Austin Healey 17
66healey fan belt on 66 bj8 Austin Healey 3
J BJ8 Radiator Fan Austin Healey 12
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
busybrit Color of BJ8 fan shroud Austin Healey 14
S Red Fan Shroud BJ8 Austin Healey 2
Dave Richards Fan Shroud Color BJ8 Austin Healey 8
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
