TR6 TR6 Fan Belt
booshoodaddy
Much trouble getting a 1/2" fan belt past crossmember on a 1976 TR6, doing an alternator conversion, reason for 1/2" belt. Have read the horror stories about doing this. Looking for the least troublesome solution.
poolboy
Usually the gap is so narrow because the motor mounts have gotten a bit squishy and settled, or the engine and transmission have "inched" a bit to forward.
Beside loosening the motor and transmission mounts and pryng the whole thing as much as you can to the rear (possibly replacing the motor mounts as part of the process), then retightening them in that position, you must be looking for an "easier" way. "Easier" being a relative term.
This is a sure fire method:
Jack up the front of the car so the front tires are just barely touching the ground or just barely off the ground, then begin to remove 2 of the 3 bolts on each end of the cross tube, loosening the 3rd one in the same location on each end so that you can rotate the cross tube enough to create more space in front of the damper.
Before doing that, you may try this one:
Jack the engine up a bit if it'll go...but spread out the force of the jack upon the sump with a board of significant dimensions between the jack and the sump.
If that alone doesn't gain you enough space, loosen the motor mounts and jack some more.... maybe ith the idea of replacing the motor mounts while you're at it.
If you've researched, nothing in this post is likely to be new...The consolation is that you won't be doing this again for a very long time.
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
T TR6 One more Rock Auto quirk - TR6 fan belt Triumph 5
jerrybny TR6 TR6 Fan Belt Deflection Triumph 2
M TR6 TR6 Alternator/Fan Belt Issues Triumph 9
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R TR6 fan shroud replacement Triumph 5
jfarris For Sale TR6 8-Blade Fan & Mounting Hardware Triumph Classifieds 0
R TR6 TR6 Electric Fan Triumph 10
T TR6 TR6 fan on TR3A Triumph 21
hondo402000 TR6 Electric Fan help needed for TR6 Triumph 5
rlich8 TR6 TR6 fan on a TR4A Triumph 3
T TR6 TR3/TR6 fan Triumph 10
T TR6 WTB - 1969 TR6 fan Triumph 7
hondo402000 TR6 Fan Shroud Installed on TR6 Triumph 8
hondo402000 TR6 TR6 fan shroud, home made Triumph 7
T TR6 Photo of TR6 mystery fan - anyone recognize it? Triumph 5
Paulus TR6 Changing a TR4A fan to a TR6 fan Triumph 3
bcbennett TR6 TR6 Heater Fan question Triumph 9
K TR6 The yellow TR6 fan on a TR3? Triumph 11
K TR6 TR3 Rad......TR6 Fan Clearances Triumph 5
prb51 TR6 TR6 Fan on a TR3 Triumph 7
M TR6 TR6 electric fan Triumph 11
A TR6 TR6 heater fan conversion?? Triumph 5
I TR6 69 TR6 fan repair Triumph 3
J TR6 Tr3-TR6 fan Adaptor? Triumph 5
J TR6 TR6 to TR3 fan- question Triumph 2
Tullamore TR6 TR6 Electric Fan Triumph 6
Brosky TR6 TR6 heater fan switch replacement Triumph 7
S TR6 replacement switch for TR6 heater fan Triumph 5
J TR6 TR6 fan in TR3A question Triumph 9
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
