TR4/4A Radiator Fan Shround
RJS
Hi ya,
I am curious if any one has ever attempted fabricating a fan shroud for the TR4A running the original engine fan? Or, even found a universal aftermarket unit which works? Something like this:
I am aware of the electric fan options but, I'd like to stay with the original fan if possible. I have the radiator duct installed which is very effective when the car is rolling >20mph. I just think a fan shroud would make a huge difference when idling in bumper-to-bumper summer traffic.
Bob
KVH
Well, I for one would lose some sleep putting anything on the fan side of the radiator. I like the electric fan option. I've never overheated since installation. I also like my original fan, but feel somehow mentally challenged because I find no tell-tale signs of which way it goes. For all I know, it's backwards, but it's the same as my other car, so I guess that's good enough. I've not been able to find helpful pictures either. My electric fan is a pusher, forward side of the radiator.
fpstude
For what it is worth, I'd verify that all components in the cooling system are correct and functioning correctly. Our TR4A is stock with no auxiliary cooling equipment and I have no overheating problem. As can be seen my personal information, I'm in central California with very warm summers.
RJS
RJS
Hi guys, Thanks for the good thoughts. I should clarify. I've not had any cooling problems. I was just curious more than anything. I've owned my TR4A 22 years, keep the cooling system in good nick and flush it every other year. In all those years I've never had it overheat and maybe twice on the hottest day of the year (90*+) while stuck in traffic for more than 5 mins has my gauge crept up. And, honestly, I more recently discovered if I bring the RPMs up to ~1500 by pulling the choke slightly, the higher fan and waterpump speed keep temps in control.
Sometime I am at the risk of overthinking things in these dark winter months...
Bob
S Installing a Radiator Fan Austin Healey 9
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
J BJ8 Radiator Fan Austin Healey 12
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
FlyingCat Spitfire Electric Radiator Fan Triumph 10
FlyingCat Spitfire Radiator and fan Triumph 5
JFS TR2/3/3A Radiator fan temp probe Triumph 3
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
Superwrench Radiator Fan Guard BJ 8 Austin Healey 4
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
rjc157 Electric radiator fan Austin Healey 11
DanLewis How far is your mechanical fan from the rear of your radiator? Spridgets 39
Patrick67BJ8 Kilmartin Radiator Fan Shroud Austin Healey 4
DanLewis Distance between mechanical fan and radiator core Spridgets 17
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
johnrip Wedge tr7 radiator fan Triumph 1
RJS Radiator Fan Bolts - need quick help Triumph 4
RJS Balancing a radiator fan[?] Triumph 18
AUSMHLY Check out this radiator fan Austin Healey 6
eschneider custom electric radiator fan switch Lotus 3
Mark Jones Electric radiator fan replacement options Triumph 3
QuickSilver Radiator Cooling Fan MG 10
G Radiator - Fan - Coolant ? Triumph 4
QuickSilver Question On Radiator Cooling Fan MG 5
T TR2/3/3A Tr3 Radiator fan loose Triumph 33
pjsmetana Spitfire Spitfire Radiator Fan Triumph 3
K radiator fan shroud Triumph 21
Mark Jones Radiator fan motor - rebuild? Triumph 4
6 Moss Recall: Tropical Radiator Fan Austin Healey 46
kyreb1862 T-Series Radiator Cooling Fan Switch MG 6
P Radiator Fan Shroud [aka finger protector] Austin Healey 1
G Ron Davis aluminum radiator and Spal fan pics..... Triumph 9
T Wedge TR8 radiator fan recommendations Triumph 0
LastDeadLast Custom radiator and electric fan stuff. Triumph 3
S Radiator Fan Clearance Austin Healey 11
Michael Oritt Wizard Radiator Austin Healey 7
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
