TR2/3/3A Radiator removal ?? electric fan vs original
Jerry
Group,
Can you get the radiator out if the original fan is not in the way. The car has an electric fan. IE: without removing the bonnet? (TR3)
Jerry
Geo Hahn
I have heard if this but never tried it - possibly removal of the thermostat housing or better yet the head would also help.
But really, unless the wings are welded or Bondo'ed to the apron I would think removal of the apron is the way to go. I dreaded it for years but was finally forced by a broken timing chain tensioner and in the end it was 'no big deal'.
TR3driver
Great Pumpkin - R.I.P
Ditto on what Geo said. By the time you hassle with the cross tube, water pump and cylinder head; it's gotta be easier to pull the apron.
Agreed, unless you are a sucker for punishment. Pull the apron. Only way I've ever seen it done was PO pulled head, then pulled radiator as after thought.
Marv
J
Jerry
Thanks group. I will point the museum people to this post so they can see that there is no easy way.
Geo Hahn
If they do remove the apron & radiator - there are possibly some other tasks worth considering 'while you're in there'.
Motor mounts, timing chain tensioner and changing the lower radiator bolts to be captive and pointing up (like a TR4) all come to mind.
TR3driver
Plus of course anything you want to do to the steering box.
B TR2/3/3A TR3 radiator removal Triumph 9
AngliaGT Early [11/73] 1974 Radiator Removal - Spridgets 4
RedTR3 TR2/3/3A TR3 Apron Removal/Radiator Replacement Triumph 10
TR4nut TR2/3/3A Radiator removal TR3A - any tricks? Triumph 12
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
FlyingCat Spitfire Radiator and fan Triumph 5
aero3113 Radiator overflow catch tank Austin Healey 15
Sarastro TR4/4A What radiator do I have? Triumph 4
Patrick67BJ8 Radiator & Engine Flush Austin Healey 10
D BT7 radiator Austin Healey 1
