DanLewis
Like some others, I've had an engine cooling problem ever since I put the 1275 in my Bugeye. It's OK (read "marginal") when driving at speed, but if I idle in traffic on a warm (~75 degrees) day, the engine temp will climb. This is with a later model plastic fan, a brand new 2-row aluminum radiator, Water Wetter instead of antifreeze, wrapped headers, and timing set at 0 degrees at idle.
I tried replacing the mechanical fan with an electric fan, and although it brought the idle temp down, it raised the temp at speed - probably because it restricts the airflow. What I did notice, however, was that at idle with the electric fan on, the airflow through the radiator was MUCH greater than it had been with the mechanical fan. That got me thinking that maybe the problem was how far the mechanical fan was from the radiator core. I measured a full 3", which seems excessive for two reasons: (1) the fan shroud only covers the top half of the fan, thus pulling air from under the radiator instead of through it, and (2) I found the following statement on SummitRacing.com in the description of a fan spacer: "Belt-driven fans work best when they are 3/4 in. to 1 in. from the radiator's surface."
So I'm going to do two things: (1) add a bigger fan spacer between the water pump and the mechanical fan to move it from 3" away to 1" away, and (2) fabricate some sheet metal to try and close off some of the space below the fan that the fan shroud left open. When I'm all done, I'll report back, but just wondered if anyone else has ever thought about moving the fan closer to the radiator?
Dan
Dan
