Mechanical tach drive
Healey Nut
Ok so Im working on the engine rebuild and have the tach drive all in pieces .
I have new oil seals for the distributor and tach drive pinion .
The pinion gear seal looks just like a regular oil seal .
when you look at the parts breakdown it shows a retainer ring and a seal . #s 122/123
The seal I have is the same O/D as the retainer ring . The only way to get the existing retainer ring out is to collapse it in on its self and destroy it .
So my question is ....Is the new modern style seal in place of the old retainer ring and rubber seal .
Or do I leave the old rubber seal in and add the new style seal on top of it ?
Healey Nut
Healey Nut
Anybody ??
steveg
Here's a better view:
https://lbcdigital.com/bmc_publications/akd1151/
Ideas besides leaving it as-is:
--maybe you could tap a sharp awl between the base of the ring and the seal rim - to get enough space to insert a small screwdriver and gradually pry the ring out
--remove the bush to the bench. Pull the drive pinion and make a shouldered shaft similar to that of the drive pinion, but longer - use it to push out the seal and retaining ring.
--maybe you can use the pinion itself to push the seal and ring out.
Healey Nut Mechanical tach drive assembly Austin Healey 4
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
T Mechanical tach options? Spridgets 17
S Mechanical Tach Repair and calibration Austin Healey 5
S Mechanical Tach Problem Debugging Austin Healey 2
S TR2/3/3A Mechanical buddies. Triumph 2
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
A BN1 Mechanical Brake Switch Austin Healey 23
B TR4/4A Mechanical fuel pump vs electric Triumph 16
K TR4/4A Mechanical fuel pump glass bowl level? Triumph 1
M Mechanical fuel pump Spridgets 33
M BE Mechanical Fuel Pump - Almost Certain Leak Spridgets 3
D TR2/3/3A Mechanical Fuel pump Triumph 3
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
AUSMHLY Watson Mechanical Brake Light Switch Austin Healey 13
tmcarthur Mechanical Fuel Pump Spridgets 9
J Mechanical tachometer to electric Austin Healey 11
DanLewis How far is your mechanical fan from the rear of your radiator? Spridgets 39
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
P Bugeye Wiper Mechanical Parts needed Spridgets 1
DanLewis Distance between mechanical fan and radiator core Spridgets 17
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
T Bypassing the mechanical fuel pump Triumph 8
regularman What was wrong with the 1500 mechanical fuel pump? Spridgets 20
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
B Mechanical & body service parts manual BJ7/BJ8 Austin Healey 2
T More on mechanical fuel pumps Triumph 32
glemon stupid human tricks mechanical advance Triumph 25
bigjones The 1500 mechanical fuel pump Spridgets 21
pjsmetana Electric Fuel Pump or carry a spare Mechanical? Triumph 15
pjsmetana Mechanical Sunpro Oil/Water Temp Gauge Triumph 5
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
TR6oldtimer TR6 TR6 Distributor mechanical advance question Triumph 4
veale001 Mechanical or Electric Fuel pump? Triumph 15
prb51 TR2/3/3A TR3 Op temp issue and mechanical gauge Triumph 7
philman Mechanical Oil Pressure Gauge Question???? Restoration & Tools 2
emann BE Mechanical Fuel Pump Installation Spridgets 0
E Body Blasting and Mechanical Work Triumph 9
7 springs for a lucas mechanical advance Triumph 1
Atrus Dizzy – Mechanical Advance Weights Spridgets 19
W Mechanical Fuel Pump Rebuild Spridgets 1
S Electric Fuel Pump vs. Mechanical Pump Triumph 18
Michael Oritt Guages--mechanical versus electrical Racing 31
drooartz Mechanical fuel pump with later 1275 Spridgets 2
V Website about most any auto mechanical question Triumph 1
B Mechanical Fuel Pump Spridgets 3
WALTER mechanical fuel pumps Spridgets 12
MGTF1250Dave TR2/3/3A TR3 or 4 Mechanical Fuel Pump Blanking Plate Triumph 4
T Electric vs Mechanical fuel pump? Triumph 3
