Mechanical fuel pump with later 1275
drooartz
The 1275 in my donor midget is a late one, and has the fitting in the block for a mechanical fuel pump (complete with blanking plate). Now, this engine is going into a Bugeye, which currently has the original 948 with mechanical fuel pump. Could that fuel pump be switched to the new motor? I know the later Spridgets all used electric pumps, but I'm curious if it would work, and what the advantages/drawbacks would be.
spritenut
It will work fine. All the cams had the fuel pump lobe.
As long as your engine has the blanking plate and not a solid casting, it'll work.
drooartz
drooartz
Thanks. I thought it might work, and that's one less thing I would need to modify to get it to work in the Bugeye. I'll at least put it on the list of things to investigate.
B TR4/4A Mechanical fuel pump vs electric Triumph 16
K TR4/4A Mechanical fuel pump glass bowl level? Triumph 1
M Mechanical fuel pump Spridgets 33
M BE Mechanical Fuel Pump - Almost Certain Leak Spridgets 3
D TR2/3/3A Mechanical Fuel pump Triumph 3
tmcarthur Mechanical Fuel Pump Spridgets 9
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
T Bypassing the mechanical fuel pump Triumph 8
regularman What was wrong with the 1500 mechanical fuel pump? Spridgets 20
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
bigjones The 1500 mechanical fuel pump Spridgets 21
pjsmetana Electric Fuel Pump or carry a spare Mechanical? Triumph 15
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
veale001 Mechanical or Electric Fuel pump? Triumph 15
emann BE Mechanical Fuel Pump Installation Spridgets 0
W Mechanical Fuel Pump Rebuild Spridgets 1
S Electric Fuel Pump vs. Mechanical Pump Triumph 18
B Mechanical Fuel Pump Spridgets 3
MGTF1250Dave TR2/3/3A TR3 or 4 Mechanical Fuel Pump Blanking Plate Triumph 4
T Electric vs Mechanical fuel pump? Triumph 3
T More on mechanical fuel pumps Triumph 32
WALTER mechanical fuel pumps Spridgets 12
S TR2/3/3A Mechanical buddies. Triumph 2
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
A BN1 Mechanical Brake Switch Austin Healey 23
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
AUSMHLY Watson Mechanical Brake Light Switch Austin Healey 13
J Mechanical tachometer to electric Austin Healey 11
DanLewis How far is your mechanical fan from the rear of your radiator? Spridgets 39
P Bugeye Wiper Mechanical Parts needed Spridgets 1
DanLewis Distance between mechanical fan and radiator core Spridgets 17
T Mechanical tach options? Spridgets 17
B Mechanical & body service parts manual BJ7/BJ8 Austin Healey 2
S Mechanical Tach Repair and calibration Austin Healey 5
glemon stupid human tricks mechanical advance Triumph 25
S Mechanical Tach Problem Debugging Austin Healey 2
pjsmetana Mechanical Sunpro Oil/Water Temp Gauge Triumph 5
TR6oldtimer TR6 TR6 Distributor mechanical advance question Triumph 4
prb51 TR2/3/3A TR3 Op temp issue and mechanical gauge Triumph 7
philman Mechanical Oil Pressure Gauge Question???? Restoration & Tools 2
E Body Blasting and Mechanical Work Triumph 9
7 springs for a lucas mechanical advance Triumph 1
Atrus Dizzy – Mechanical Advance Weights Spridgets 19
Michael Oritt Guages--mechanical versus electrical Racing 31
V Website about most any auto mechanical question Triumph 1
