philman
Does it matter what diameter tubing you use for a mechanical oil pressure gauge? I am using a larger diameter metal tubing and am wondering if the accuracy suffers at lower ranges.
I also have a "T" fitting with the idiot lamp sensor and am wondering if the interaction between the two could give false indications.
