Dizzy – Mechanical Advance Weights
Atrus
As I had posted previously, the primary spring on my mechanical advance was completely ruined somehow. I’ve been reading up on how to tune the 25D, and figured for the $5 it cost for a “universal” spring kit, I’d play around and give it a whirl. While playing, I’ve thrown a couple of different springs on there just to see how tight it makes the advance.
What I am noticing is that my weights have some play in them when there’d be no advance applied. Is this common? They can’t advance outward nearly as far as when the actual advance arm moves, but oscillating the dizzy shaft clockwise and counterclockwise, you can hear them rattling. Using a small screwdriver, I can move them without resistance.
Atrus
Atrus
Very cool, I was wondering about putting in a knock sensor. I'll have to check this out at home when I have more time. Thanks for the link!
Bruce_B
Can anyone answer there the actual knock sensor unit itself goes? I see that Knocksense sells a used Bosch unit, but where is it mounted?
thanks...
Knock sensor in an old clanky pushrod engine? I have my reservations.
I'm feeling skeptical today!
Atrus
Atrus
it's not "old and clanky", but I have one in my 3.8L pushrod engine ;). False knock (and knock retard) is common in the L36/L37 GM engines. PCM senses knock, it pulls timing. In the A-series, however, it'd be good just to monitor it. No detriment to having one, other than your wallet /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Atrus
Atrus
don't mean to be a pain, but anyone have any idea on these weights? Is it OK to be a little loose?
Platinum
Define: "loose."
Where's Jeff from AdvanceDist when we need him?
Atrus
Atrus
I guess I don't have a quantitative measurement...standby, I'll try with the camera to get a pic.
Atrus
Atrus
OK, I see no way to get a good pic...let's put it this way, the advance arm gap = 13*, I'd say it's about that much rotational play out the outward corner of the one near the primary, about 2/3 that much on the secondary. Secondary spring is loose when at rest, primary has some tension on it.
racingenglishcars
From what I understand then, it doesn't sound completely wrong. the weights should be loose enough to move freely. The light spring should be tight and the heavy spring should be loose, when at rest. What is probably wrong is the advance curve. This is difficult to get right. Trial and error might do it, but for good results use go to advanceddistributors. Or use a dyno and many hours of work.
healeyboz
I agree! Deciding how much time is worth spending on getting it right through trial and error is the question. I sent mine of to Advance Distributors and can rest assure that it is darn near perfect! Hopefully one less factor during the initial start-ups.
Atrus
Atrus
Well, I sent a lengthy e-mail to Jeff, and he said that's a common debate. He stated that Lucas didn't put any specs out for a stock dizzy for a reason - there are HUGE variances. So, basically, what I have right now is very normal.
He's given me two options. He'll completely rebuild my stock unit - new bushings, lessen the advance weight play. new cap/rotor (mine are cheap junk), recurve it and he'll put in the pertronix unit there as he stocks them. The other option is that he sells the pertronix distributors and he'll recurve that for my needs for the same price. He says that he truly feels his rebuilt stock units have much better components than the overseas built pertronix units. He's going to charge me the same for either option.
So, I have some thinking to do...looks like the completely rebuilt stock may be the way to go. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
healeyboz
Rest assure that Jeff knows what he is talking about. You will be happy with having him do the work!! Hap uses him and recommended me to him. The distributor looks great and everything is relatively new. Can't wait to see how well it works when running!!!
Sarastro
I'm a little surprised that they offer the same distributor for sprite, MGA, MGB, TR3/4 and so on. Is there really no difference between the stock advance curves for all these cars, or are they just close enough that you can get by with a single replacement distributor?
jlaird
I would be willing to bet a beer that they were all different. Heck, the engines were different. Stands to reason. But then they are LBCs so who knows.
Atrus
Atrus
according to Jeff and several online sources I have read, that's the problem. These cars all do have different advance curves desprite using the same housing. In fact, Vizard states this - the car doesn't care what kind of dizzy it has, as long as the curve is set up. Basically any dizzy can be curved to fit any car.
Regardless, when I rebuild the engine next year I will have a distributor custom curved. My #1 goal right now is to get the car running decently enough to drive this spring/summer/fall. I had it going well enough to marginally drive it, although it wasn't correct last year. Makes total sense that I could never dial it in correctly with the spring missing on the primary. I have two brand new (not rebuilt) HS2's on the car, so I am thinking the dizzy is it.
D MGB 25D dizzy rebuild MG 29
tri_carb_healey Dizzy cap for petronix ignitor Austin Healey 8
weewillie can't tighten dizzy clamp Spridgets 3
drooartz Winter projects: carb and dizzy rebuild MG 26
DRKizer Pertronix Flame-Thrower "HP" dizzy for Brit cars Racing 6
bugedd Dizzy question Spridgets 9
DNK Dizzy part Triumph 4
drooartz Running top-entry dizzy cap on Sprite Spridgets 15
bighealeysource distributor lubrication knob on side of dizzy Austin Healey 3
Steve1970 What's the 3 wires below the dizzy, from the block Triumph 10
P CHECKING DIZZY CAP Spridgets 10
jlaird Miss Agathas Dizzy Spridgets 7
jlaird Dizzy off to Jeff Spridgets 6
tahoe healey dizzy follow up Austin Healey 7
Jim_Gruber Dizzy Question - Micro Adjustment Wheel 25D Dizzy Spridgets 7
tahoe healey Dizzy problem Austin Healey 5
tahoe healey Spark plug connector and dizzy repair Austin Healey 2
equiprx I keep gettting a wet dizzy. Jaguar 1
jaegzie Dizzy turned to far - hitting generator/tach gear Spridgets 12
B Dizzy Replacement - Petronix Austin Healey 6
Jim_Gruber Removing Dizzy - issues Spridgets 4
T Got my dizzy recurved by Jeff Schlemmer..... Triumph 4
J Dizzy vacuum line, manifold drain lines routing? Austin Healey 7
19_again GT6 Lucas Distributor cap on Delco D204 Dizzy GT6+ Triumph 6
angelfj1 New Improved Dizzy Rotors Triumph 3
tinman58 My dizzy Triumph 15
tahoe healey Dizzy Austin Healey 20
jlaird Question-Dizzy Spridgets 1
WALTER Vacuum source for dizzy Spridgets 4
G Brosky, ya got a picture of dizzy drive gear set.. Triumph 10
R 123 New Dizzy [Ignition System] Austin Healey 2
K Dizzy without Vac Advance Racing 2
poolboy Lucas Dizzy with micro timing adjustment question Triumph 20
eejay56 84 Ford ranger Dizzy clamp bolt Other Cars 7
Z MK IV 1948-1952? 1.5L Dizzy Jaguar 0
texas_bugeye Dizzy vac question [NEW DISCOVERY] Spridgets 2
prb51 TR2/3/3A Tr3 Dizzy's Triumph 2
specialsports Mallory Dizzy Other British Cars 10
Bret I'm getting Dizzy MG 7
NutmegCT TR2/3/3A Dizzy dizzy - TR3A - Lucas 25D Triumph 18
8 DIZZY WIRE Triumph 9
Atrus 1/8” Capillary Tubing [Dizzy Advance] Spridgets 8
G NEED A QUICK ANSWER...setting drive dog for dizzy Triumph 8
T Dizzy lost thread Triumph 24
guzzul I have a wobbly dizzy.... Triumph 6
Woodie hs2 & vac to dizzy - urgent - car apart in drivewy Spridgets 11
S Dizzy cap, HT leads Austin Healey 14
jlaird Dizzy set up Spridgets 4
R Dizzy Quiz Triumph 4
S Dizzy options Triumph 5
