tahoe healey
A while ago I suspected a dizzy problem and sent it off to Jeff at Advanced Distributor at the recommendation of this forum. After some minor set-backs (broken Lucas dist. cap and too short wires) with Jeff's help my BJ8 now goes like a "bat out of heck". Smooth as silk. The intermittent hesitation I've had forever is gone! The acceleration is much improved. Turns out I had a slightly bent dizzy shaft with a little side movement. It came back so clean it didn't look like mine. With the new advance springs the timing needed to be advanced a bit to get max power. Once the sweet spot was found (with Jeff's help)she purrs with power. Best money I've spent on the car in years. I highly recommend Advanced Distributor and Jeff is a great, patient guy.
