paulsherman
After re-doing my ignition (new coil, points and condenser) I thought I would check the plug wires for continuity. With each plug wire plugged into the cap, I check for continunity from the inside of the cap to the spark plug end of each plug wire. Everything was fine. But when I checked for continunity in the lead from the center terminal in the cap to the end of the wire that plugs into the coil, NOTHING. I even depressed the carbon thingy in the top of the cap (the thing that touches the top of the rotor, still no continuity. I further checked this wire after removing it from the dizzy and had good continuity.
WHAT THE heck IS GOING ON?
Thank you
Thank you
