Checking a temp guage
markctr3
If I check the mechanical sending unit that screws into the thermostat housing with a pyrometer, should that give me the same temperature reading as the gauge in the dash?
sammyb
More or less. Expect some margin of error -- maybe 5 degrees or so.
dklawson
You can probably improve the readings from the pyrometer by cleaning a spot on the thermostat housing and painting it with a spot of satin black paint before your measurements.
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
T General MG Checking tiers tread MG 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
K TR2/3/3A Checking steering box End Play? Triumph 5
B TR2/3/3A Checking oil in rear axle Triumph 2
T TR4/4A Your procedure for checking out a new-used engine Triumph 6
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
E TR4/4A Checking a generator Triumph 12
5 Checking The Spedo Spridgets 11
PSJ Checking for interest - meeting of NW Organization of Spridget Handymen In Transit Spridgets 6
vette Checking RPMs Austin Healey 14
DanLewis Checking condition of rear springs on a Bugeye Spridgets 17
A TR2/3/3A checking axle float triumph tr3a Triumph 10
Anthony_S TR2/3/3A TR3a valve cover gasket - checking clearances Triumph 8
RickAnderson Checking an Engine Not in the Car? MG 2
M Checking rear break drums and pads Triumph 7
T Checking OD function w/out solenoid handy? Triumph 4
P Checking oil levels Triumph 6
drooartz Checking transmission/OD levels MG 14
N Checking a rebuilt engine Austin Healey 15
T Anyone interested in checking out a BN2 in NM? Austin Healey 14
M Newbie: Just Checking In MG 7
P CHECKING DIZZY CAP Spridgets 10
Gundy Checking B's tranny oil MG 26
T Checking for front suspension wear Spridgets 4
6 Checking out lever arm shocks Austin Healey 3
drooartz Checking a ribcase transmission Spridgets 2
2wrench Checking the thrust washers.....Dale? Triumph 3
KindredSpirit Just checking about spark plugs. Austin Healey 2
vping Checking an axle ratio MG 2
Hap Waldrop Plastigauging for checking crankshaft clearences Spridgets 7
S TR2/3/3A door strap checking tr3 Triumph 8
M Another New Member - Just checking things out MG 9
G Checking & filling shock absorber fluid Spridgets 9
wkilleffer Checking distributor shaft wobble MG 37
N MGB Checking out MGB's Betwix Here and There MG 3
M Checking/Changing Limited Slip Diff. Oil on XJS Jaguar 2
aeronca65t Checking Pertronix Unit Restoration & Tools 1
S Paint Checking on the Hood Austin Healey 4
G Checking leak in used radiator Restoration & Tools 3
TNMGB Checking/adding gearbox oil?? MG 34
D Checking Tranny Fluid Level Spridgets 5
N MGB 1978 MGB Coolant Level Checking MG 3
B MGB Another new owner of an MGB checking in MG 9
Andy Blackley Checking my 74B MG 2
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
G Smith's temp gauge repair Restoration & Tools 4
