wkilleffer
I spoke with some people, including Joe Curto, about the carb trouble I'm having, and they said to check the shaft wobble on the dizzy before trying to adjust the carbs. The dizzy had some trouble with frozen weights when I cracked it open the other day, and Joe said that can be a sign of other trouble, like a worn out shaft.
Is that checked by wiggling the top of the shaft that's inside the dizzy cap? I can see how even a small amount of wobble could keep the points open too long.
A new distributor is kind of pricey, when they're even available. Joe mentioned putting in an electronic system to prolong the life of the existing unit. He said a Pertronix system would work, but that a Crane would be best as they aren't affected by shaft wobble. Vicky-Brit also has a Flame Thrower distributor that looks like a new dizzy with Pertronix innards.
I'm a little wary of electronic systems, but am open-minded when it comes to keeping the car running. Any advice or suggestions would be appreciated.
Thank you,
Thank you,
