TR2/3/3A Checking oil in rear axle
BobbyO
In what position should the car be when you check the oil in the rear axle? Level or can you jack up the rear in order to more easily get to the fill plug? If jacked up, should you fill to overflowing then lower the car as you could do when filling the gearbox? Any help will be appreciated.
Geo Hahn
Ideally it would be on all fours on the floor or lift - but I doubt it is really critical. If you have to jack the rear you could probably just leave it a smidge less than totally full - maybe and eighth inch below the lip of the opening.
If you want to be exact then yeah, fill it and then lower for a spell to let the excess runn out, then up again to thread in the plug.
TR3driver
Great Pumpkin - R.I.P
I'm with Geo, don't believe a slight overfill (like you'd get checking the level with the rear jacked up) will hurt anything at all. Too much might increase it's tendency to mark it's spot, but even that isn't necessarily a Bad Thing.
P Checking oil levels Triumph 6
Gundy Checking B's tranny oil MG 26
M Checking/Changing Limited Slip Diff. Oil on XJS Jaguar 2
TNMGB Checking/adding gearbox oil?? MG 34
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
T General MG Checking tiers tread MG 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
K TR2/3/3A Checking steering box End Play? Triumph 5
T TR4/4A Your procedure for checking out a new-used engine Triumph 6
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
E TR4/4A Checking a generator Triumph 12
5 Checking The Spedo Spridgets 11
PSJ Checking for interest - meeting of NW Organization of Spridget Handymen In Transit Spridgets 6
vette Checking RPMs Austin Healey 14
DanLewis Checking condition of rear springs on a Bugeye Spridgets 17
A TR2/3/3A checking axle float triumph tr3a Triumph 10
Anthony_S TR2/3/3A TR3a valve cover gasket - checking clearances Triumph 8
RickAnderson Checking an Engine Not in the Car? MG 2
M Checking rear break drums and pads Triumph 7
T Checking OD function w/out solenoid handy? Triumph 4
drooartz Checking transmission/OD levels MG 14
N Checking a rebuilt engine Austin Healey 15
T Anyone interested in checking out a BN2 in NM? Austin Healey 14
M Newbie: Just Checking In MG 7
P CHECKING DIZZY CAP Spridgets 10
T Checking for front suspension wear Spridgets 4
6 Checking out lever arm shocks Austin Healey 3
drooartz Checking a ribcase transmission Spridgets 2
2wrench Checking the thrust washers.....Dale? Triumph 3
KindredSpirit Just checking about spark plugs. Austin Healey 2
vping Checking an axle ratio MG 2
Hap Waldrop Plastigauging for checking crankshaft clearences Spridgets 7
S TR2/3/3A door strap checking tr3 Triumph 8
M Another New Member - Just checking things out MG 9
G Checking & filling shock absorber fluid Spridgets 9
wkilleffer Checking distributor shaft wobble MG 37
N MGB Checking out MGB's Betwix Here and There MG 3
M Checking a temp guage Triumph 2
aeronca65t Checking Pertronix Unit Restoration & Tools 1
S Paint Checking on the Hood Austin Healey 4
G Checking leak in used radiator Restoration & Tools 3
D Checking Tranny Fluid Level Spridgets 5
N MGB 1978 MGB Coolant Level Checking MG 3
B MGB Another new owner of an MGB checking in MG 9
Andy Blackley Checking my 74B MG 2
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
