TR2/3/3A TR3a valve cover gasket - checking clearances
Anthony_S
I know this might be a silly post but I was wondering if anyone knows if you can get a valve cover gasket from your local auto parts store? Is it a standard size thing or do I have to order it online? I was hoping to not have to order it. I wanted to check my tappet clearances and what not this weekend but don't want to remove the cover unless I have a new seal. Any thoughts are welcome :smile: Thoughts on checking the clearances are also good as I have not done this before. Read about it in the manual though and it seems pretty easy.
Thanks!
Darrell_Walker
M_Pied_Lourd
Well, another option is to buy a sheet of cork gasket material and make your own. Not too hard to do.
Cheers,
M. Pied Lourd
martx-5
For future reference, I've always installed the original style cork gasket buy gluing it on the valve cover side using 3M weather strip adhesive. After it dries, I spread some heavy grease on the cork and install. I don't have any leaks, and the gasket will always come off, intact, with the cover. It can be removed many times and used again. Just smear a new layer of grease on the cork.
PeterK
Did you ask at your local auto parts store?
Have you removed the cover and checked to see if the gasket is intact and reuseable?
Anthony_S
Anthony_S
I did ask the advanced auto in town with no luck but thought maybe someone here might know a bit more and no I have not removed it because I don't want to remove it unless I have one to replace it in case the other isn't reusable and intact.
TR3driver
Great Pumpkin - R.I.P
I used to do the same thing, except I used RTV "form a gasket" to glue the cork to the cover and laid it gasket side down on a flat surface while the RTV hardened. That helps make up for any irregularities in the original cover.
But now I use one of Justin's "forever" gaskets. I've lost track of how long, or how many times it's been on and off (I even moved it from the wrecked TR3A to the current TR3) and it works great.
DanB
Anthony, what you can do is to remove the two nuts and see if you can move the cover any at all by hand. If you can, it probably isn't glued down, so the last owner may have used a trick similar to Art's. Take a razor blade to help remove it from the head surface and keep it intact and attached to the valve cover.
Are you going to use feeler guages to adjust the valves? There is also a tool that will do it by clicks. I don't have one but have borrowed one before. Generally I use the feeler guage though.
Dan B.
So. Chas. WV
66 TR4AIRS EFI
80 TR7 DHC
Anthony_S
Anthony_S
Thanks for the tip, I planned on using the feeler gauge method. I also learned about the rule of 9's
S Price check on TR3A valve cover Triumph Classifieds 0
2billydavies TR2/3/3A anyone know what this valve is and where it goes on a TR3a? Triumph 14
M TR2/3/3A Valve Train Noise TR3A Triumph 2
ekamm TR2/3/3A Tr3a heater valve question Triumph 12
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
