TR2/3/3A Checking steering box End Play?
karls59tr
Bronze
I am a little confused as to the proper way to set the end play. The steering box is in a vice with the worm and bearings,shims and end plate in position. The magnetic base dial gauge is mounted and ready to go. To get an initial reading do I insert the rocker shaft into the worm gear(just hand held not with the cover bolted on?) and move it in the direction of the dial gauge to see what reading I get then remove shims as recquired until I get a zero reading?
Also for a split column shaft should the bushing at the split be installed when I do the measurement?
TR3driver
Great Pumpkin - R.I.P
I added a shim (to get some end play), then used the rocker shaft and loosely assembled Pitman arm to force the worm both ways to measure the play. It will naturally want to stay in the middle so just going one way won't give you an accurate measurement. Once you've got a measurement, subtract shims equal to the measurement or a bit more (the shims only come in .0024" steps) and you're done.
Didn't occur to me to try it before installing the upper bushing, but might be better that way. Normally wouldn't make a difference, I think, but if either the tube or shaft are a bit bent, it might affect the end float measurement.
TexasKnucklehead
Just to be clear, you don't need the rocker shaft at all to set the end play. The dial indicator should be on the far end of the shaft. You can use a screwdriver or anything between the worm and housing to try to shift the shaft in/out to see the end-play. The bushing doesn't impede the end-play measuring as much as the next adjustment -setting the rocker tension by finding the sweet-spot/tight-spot in the center of the worm. My shaft wasn't bent, but appeared so since the worm wasn't exactly centered on the end of the shaft. (With the worm bearings snug, spinning the shaft shows the far end -near the coupling- to spin in a concentric or oblong circle instead of the center staying centered.) So, in my case, finding the "sweet-spot" would have been impossible with the busing installed.
K
karls59tr
Bronze
Well 14-16 lb torque makes the shaft too tight to turn by hand so I backed the bolts off somewhat.
Can I set the rocker tension (adjustment screw) with the box in the vice to see if there is a slight tension at the center. I have a spare steering wheel I can mount to turn the worm shaft?Would this help to at all to find the "sweet-spot" or should I just wait till the whole assembly is bolted into the car and then set the adjustment screw?
If I seal the brass shim at the gasket with a thin layer of sealant is this going to affect the end play much?
TexasKnucklehead
The end float must be set first, and it will be almost impossible to find the sweet spot of the worm once everything is together. The sweet spot is small, and barely perceivable on the bench. The added resistance of the bushing (which is very small) is greater than the sweet spot.
If you had to back off the end cap bolts to be able to turn the shaft/wheel, you don't have enough shims -in other words not enough end play. The end cap is prone to distortion from over tightening with too few shims between it and the housing. Once bent, it has a greater tendency to leak the oil that needs to be in there for normal use. If you decide to use some sealant between each or any of the shims, the amount of sealant that doesn't squeeze out will add to the thickness of the shim, and increase the end float. Since you had to back off the cap screws, it sounds like the 14-16lbs was directly pressing against the bearings, instead of having tension between the cap and housing. The end float is the space left over after the cap screws are torqued, between the bearings and races. As you have seen or can imagine, too little end float can make the wheel impossible to turn. Excessive end float will cause excessive steering wheel float -meaning the steering wheel will have to move a far amount right or left, before any of that motion is transferred to the steering. The end float is a delicate balance and worth the time it takes to set properly.
TR3driver
For sure something is wrong, there shouldn't be enough drag in those bearings to notice even with .001" preload (negative end play).
Did you have the bolts torqued down when checking end float?
I would definitely set the peg adjustment on the bench, and without the steering wheel. Just turn the shaft with your fingers.
Might depend on what sealant you use; but with Hylomar I couldn't tell the difference with or without.
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
T General MG Checking tiers tread MG 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
B TR2/3/3A Checking oil in rear axle Triumph 2
T TR4/4A Your procedure for checking out a new-used engine Triumph 6
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
E TR4/4A Checking a generator Triumph 12
5 Checking The Spedo Spridgets 11
PSJ Checking for interest - meeting of NW Organization of Spridget Handymen In Transit Spridgets 6
vette Checking RPMs Austin Healey 14
DanLewis Checking condition of rear springs on a Bugeye Spridgets 17
A TR2/3/3A checking axle float triumph tr3a Triumph 10
Anthony_S TR2/3/3A TR3a valve cover gasket - checking clearances Triumph 8
RickAnderson Checking an Engine Not in the Car? MG 2
M Checking rear break drums and pads Triumph 7
T Checking OD function w/out solenoid handy? Triumph 4
P Checking oil levels Triumph 6
drooartz Checking transmission/OD levels MG 14
N Checking a rebuilt engine Austin Healey 15
T Anyone interested in checking out a BN2 in NM? Austin Healey 14
M Newbie: Just Checking In MG 7
P CHECKING DIZZY CAP Spridgets 10
Gundy Checking B's tranny oil MG 26
T Checking for front suspension wear Spridgets 4
6 Checking out lever arm shocks Austin Healey 3
drooartz Checking a ribcase transmission Spridgets 2
2wrench Checking the thrust washers.....Dale? Triumph 3
KindredSpirit Just checking about spark plugs. Austin Healey 2
vping Checking an axle ratio MG 2
Hap Waldrop Plastigauging for checking crankshaft clearences Spridgets 7
S TR2/3/3A door strap checking tr3 Triumph 8
M Another New Member - Just checking things out MG 9
G Checking & filling shock absorber fluid Spridgets 9
wkilleffer Checking distributor shaft wobble MG 37
N MGB Checking out MGB's Betwix Here and There MG 3
M Checking/Changing Limited Slip Diff. Oil on XJS Jaguar 2
M Checking a temp guage Triumph 2
aeronca65t Checking Pertronix Unit Restoration & Tools 1
S Paint Checking on the Hood Austin Healey 4
G Checking leak in used radiator Restoration & Tools 3
TNMGB Checking/adding gearbox oil?? MG 34
D Checking Tranny Fluid Level Spridgets 5
N MGB 1978 MGB Coolant Level Checking MG 3
B MGB Another new owner of an MGB checking in MG 9
Andy Blackley Checking my 74B MG 2
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
