guzzul
Sounds painful doesn't it?
I pulled the distributor on my Spit and I notice there is some 'play' in the top of the shaft. Holding the distributor in my hand, I can 'wobble' the top of the shaft, maybe 8-10 thousands.
This is a Lucas eletronic unit, and I also noticed there are some scuff marks on the reluctor where it has been touching the pickup. Not all the way around, and not deep scuffs, but about 1/3 of the circumference has obviously been touching pretty close to the pickup. Maybe there's a bit of wear in the shaft, and its wobbling a bit as it spins? Probably not good for performance.
Can this be fixed easily? I originally thought I would replace the Lucas guts with a Pertronix Ignitor, but now I'm wondering whether I should replace or rebuild the entire unit. Are these distributors relatively easy to rebuild?
