Mechanical Fuel Pump
bberwick
I know I should probably be using an electric fuel pump for my '61 Bugeye 948, but I've decided to go with a mechanical one. Being quite a novice, does the rocker arm of the fuel pump simply slide into the port, or does it attach to something inside?
Bob
Tim Hollister
Bob,
It slips into the port and rides on a special lobe on the camshaft as that is where it gets it's "drive." Pretty simple operation and a good question too.
Tim
B TR4/4A Mechanical fuel pump vs electric Triumph 16
K TR4/4A Mechanical fuel pump glass bowl level? Triumph 1
M Mechanical fuel pump Spridgets 33
M BE Mechanical Fuel Pump - Almost Certain Leak Spridgets 3
D TR2/3/3A Mechanical Fuel pump Triumph 3
tmcarthur Mechanical Fuel Pump Spridgets 9
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
T Bypassing the mechanical fuel pump Triumph 8
regularman What was wrong with the 1500 mechanical fuel pump? Spridgets 20
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
bigjones The 1500 mechanical fuel pump Spridgets 21
pjsmetana Electric Fuel Pump or carry a spare Mechanical? Triumph 15
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
veale001 Mechanical or Electric Fuel pump? Triumph 15
emann BE Mechanical Fuel Pump Installation Spridgets 0
W Mechanical Fuel Pump Rebuild Spridgets 1
S Electric Fuel Pump vs. Mechanical Pump Triumph 18
drooartz Mechanical fuel pump with later 1275 Spridgets 2
MGTF1250Dave TR2/3/3A TR3 or 4 Mechanical Fuel Pump Blanking Plate Triumph 4
T Electric vs Mechanical fuel pump? Triumph 3
T More on mechanical fuel pumps Triumph 32
WALTER mechanical fuel pumps Spridgets 12
S TR2/3/3A Mechanical buddies. Triumph 2
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
A BN1 Mechanical Brake Switch Austin Healey 23
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
AUSMHLY Watson Mechanical Brake Light Switch Austin Healey 13
J Mechanical tachometer to electric Austin Healey 11
DanLewis How far is your mechanical fan from the rear of your radiator? Spridgets 39
P Bugeye Wiper Mechanical Parts needed Spridgets 1
DanLewis Distance between mechanical fan and radiator core Spridgets 17
T Mechanical tach options? Spridgets 17
B Mechanical & body service parts manual BJ7/BJ8 Austin Healey 2
S Mechanical Tach Repair and calibration Austin Healey 5
glemon stupid human tricks mechanical advance Triumph 25
S Mechanical Tach Problem Debugging Austin Healey 2
pjsmetana Mechanical Sunpro Oil/Water Temp Gauge Triumph 5
TR6oldtimer TR6 TR6 Distributor mechanical advance question Triumph 4
prb51 TR2/3/3A TR3 Op temp issue and mechanical gauge Triumph 7
philman Mechanical Oil Pressure Gauge Question???? Restoration & Tools 2
E Body Blasting and Mechanical Work Triumph 9
7 springs for a lucas mechanical advance Triumph 1
Atrus Dizzy – Mechanical Advance Weights Spridgets 19
Michael Oritt Guages--mechanical versus electrical Racing 31
V Website about most any auto mechanical question Triumph 1
