TR6 TR6 Distributor mechanical advance question
TR6oldtimer
Here is a picture of the mechanical advance out of a '73 TR6. Notice the 16 stamped on what I will call the advance stop. I have another distributor I got years ago from TRF and it has a 13 stamped in the same place. The question is is my assumption correct that each limits the mechanical advance, and if so, is there a preference? The engine has a GP2 came.
TR3driver
Great Pumpkin - R.I.P
I can only answer half the question: Yes, that stop is what limits the mechanical advance.
If you are running the stock compression ratio, then I assume most likely the motor would tolerate some more advance. But that's strictly a WAG, worth no more than it costs.
Brosky
Ray,
Those advance springs should be exactly the same. If one is stretched more than the other in a retracted position, the advance may not be what it was intended to be.
And the 22D distributor that I had that the housing was stamped 1975 had 13 stamped on the plate.
TR3driver
It depends on the particular model of distributor, but for most Triumphs the springs were different. This gives the advance curve two different slopes, a more rapid increase at lower rpm and a slower increase at higher rpm.
I show two different distributors used in 1973 on US-spec TR6, one limited to 13 (cam) degrees advance @ 2500 (cam) rpm, and the other 10 @ 1850
Brosky
I stand corrected Randall. I was not aware of that and had only seen matching springs in my GM days, so I assumed (incorrectly) that these should be the same. Thanks for pointing that out.
A TR6 TR6 Distributor cap issue Triumph 4
smaceng TR6 TR6 distributor advance and retard hook up Triumph 6
I TR6 Correct way to tighten distributor on TR6? Triumph 1
I TR6 Distributor help on TR6 Triumph 5
G TR6 1974 TR6 distributor advance spring specs Triumph 6
B TR6 'Cutting-down' a TR6 distributor ? Triumph 26
W TR6 Tr6 1974 Distributor Triumph 7
veale001 TR6 TR6 Distributor problem........................... Triumph 39
I TR6 TR6 distributor suggestions? Triumph 12
J TR6 TR6 distributor info needed... Triumph 8
jerrybny TR6 69 TR6 Distributor Triumph 1
I TR6 69 TR6 distributor/vacuum advance/retard help Triumph 4
T TR6 TR6 distributor removal - tips on tach drive Cable Triumph 5
N TR6 Need TR6 distributor advance weight spring Triumph 3
jerrybny TR6 73 TR6 Distributor question Triumph 4
G TR6 tr6 distributor Triumph 13
tr6web TR6 Tachometer and distributor problem - '72 TR6 Triumph 6
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
