Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer
Firm
Member
So my new project 79 Spitfire 1500 isn't getting any fuel. The previous owner had bypassed the mechanical pump in favor or an electric, which is currently dead as well. I'd like to use the original mechanical pump rather than just running another electric job, so I braved the blizzard on Saturday and unbolted the mechanical pump. My intention is to rebuild it, or if I can't get a rebuild kit, buy a replacement pump.
Couple questions based on my observations:
1. When I removed the pump it was bolted directly to the block and someone had used some hi-heat silicone as a gasket. I thought the 1500 Spitfires all had a spacer between the pump and the block? True? Maybe the last guy couldn't get the mechanical pump to work because he didn't have the spacer installed?
2. Is there a rebuild kit available for the mechanical pump? I can't seem to find one at any of the usual suppliers? (unless I am just blind)
3. Is there a particular trick to re-installing the pump to ensure it's engaged the cam correctly? (this is my first time working on a mechanical pump)
Thanks!
F
Firm
Member
Nobody yet...Maybe some pics of the pump will help:
Moss Motors lists the following:
377-410 Mechanical Fuel Pump for 78-80
Note: This pump uses spacer 377-415
377-400 Fuel Pump, Mechanical for 73-78
Note: This pump does not use a spacer.
The above would suggest that my car (a 79) should use 377-410 WITH a spacer. However, before I go ahead and order something that doesn`t work in my car I like to confirm. The pump pictured above is the one I pulled from my car, which had NO spacer on it when I pulled it. Whether it was working or not is anyone`s guess, however there does seem to be a shiny spot on the arm where I assume the cam was engaging it. Can anyone tell whether the pictured pump is supposed to be used with a spacer?
3798j
Bronze
According to The Roadster Factory and Spitbits catalogs, early 1500 engine fuel pumps didn't require a spacer and they had a straight arm (up to FM93157), later ones did require a spacer and they had a curved arm (FM93158 on). Yours appears to be a straight arm (I think).
https://trf.zeni.net/spitfireGB/26.php
F
Firm
Member
Thanks - that lines up with what the Moss catalogue says. Maybe someone put a earlier pump on my car? Can anyone confirm whether the pump I have pictured above is consider a curved or straight arm?
Aaron Johnson
That is a straight arm pump that is used without the spacer.
As as far as installing ther is nothing tricky about it. Just push it in and bolt it up.
I don't believe there is a rebuild kit for them. They were a disposable part.
F
Firm
Member
Thanks Aaron.
Since I am going to be buying a new pump anyway, should I buy the correct (for my 79) curved arm pump and spacer?
Aaron Johnson
I don't really think there is a difference between the two as far as performance. Which one is cheaper? If you are looking for original than get the spacer and curved. Be careful though as it needs two gaskets and and has two spots to leak oil if it isn't sealed correctly.
G Spitfire Spitfire 1500 differential whining Triumph 6
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
B Spitfire Advice on swapping to J Type OD with 1500 engine in 69 Spitfire Triumph 13
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
F Spitfire Spitfire 1500 Dash Lights Triumph 1
W Spitfire Spitfire 1500 Steering Column Triumph 3
dklawson Spitfire Clutch Kit Preference - 1500 Spitfire Triumph 3
Anthony_S Spitfire Spitfire 1500 for sale in my area Triumph 1
S Spitfire Is a 1973 spitfire a 1500 or a mark IV? Triumph 7
dklawson Spitfire Spitfire MkIV/1500 - Factory Front Spoiler? Triumph 3
dklawson Spitfire Spitfire MkIV/1500 Body Gaps - Bonnet to Bumper Triumph 2
F Spitfire Spitfire 1500 Door Handle Removal Triumph 1
F Spitfire SUs On a Spitfire 1500 Triumph 14
Scott_Hower Spitfire Late Spitfire 1500 CV driveshaft Triumph 3
F Spitfire Spitfire 1500 - Stromberg CD 150 Question Triumph 9
F Spitfire 1500 Spitfire Windshield Glass, Gasket and Install Triumph 12
Don_R Spitfire Spitfire MKIV/1500 parts book Triumph 2
F Spitfire Spitfire 1500 Electrical Question?????? Triumph 4
F Spitfire 77 Spitfire 1500 Questions Triumph 3
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
mikecyc72usa Spitfire First Autocross in my Spitfire 1500 Triumph 29
F Spitfire 1500 Spitfire Engine Noise Triumph 14
A Spitfire TRIUMPH SPITFIRE MKIV 1500 Triumph 2
K Spitfire 60’s spitfire body swapped onto a 1500 cassis Triumph 3
M Spitfire Spitfire 1500 OD transmission Triumph 9
A Spitfire Triumph Spitfire 1500 Triumph 8
K Spitfire Spitfire Mk IV tonneau =Spitfire 1500 tonneau? Triumph 2
dklawson Spitfire Crank Endfloat and Oil Pumps - Spitfire 1500 Triumph 9
bowiderberg Spitfire Whitworth on a Spitfire 1500? Triumph 8
This14u Spitfire 1500 Spitfire Header Recommendation Triumph 0
pjsmetana Spitfire Spitfire 1500 TC Triumph 2
frankenstang57 Spitfire Spitfire 1500 fast road cam question Triumph 4
1965_MGB Spitfire Junkyard Find, Spitfire 1500 I think Triumph 6
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
c5racer Fit an exhaust manifold from a 1500 Spitfire? Spridgets 2
