Bypassing the mechanical fuel pump
tdskip
Hi guys - so while dong a test drive yesterday to see if I had sorted out the OD issues the TR6 started to stumble and loose power. Quick pull of the choke, stumbling went away, so it was pretty easy to confirm it was fuel. Pull to the side of the road and find that the fuel filter is dry, despite the fuel tank being half full. So that suggests the mechanical fuel pump being the culprit.
Run home (need the exercise anyway), quick trip to drop my daughter off at Brownies, and then I installed an low pressure electric fuel pump in the engine bay. Let it prime for 15 seconds and then she fired right up and ran great.
Due to being on the side of the road and not having much spare time I connected the fuel pump so it pulls through the fuel filter and <span style="text-decoration: underline">pushes</span> through the presumed dead mechanical pump. I'll put in a proper mechanical pump but that has me wondering if there would be any issues in running it like this for a while?
What do you think guys?
NutmegCT
My experience: when the fuel pump died (in heavy traffic on Memorial Day weekend, in the hottest week in ten years ...), I had a friend pick me up and drive me home to fetch an electric pump I had never used.
Drove back to the "site of the embarrassment", and spliced it in line, in the engine bay. Didn't feel like crawling under the car in the Memorial Day conditions.
The pump pushed fuel through the old pump and into the carbs. Engine ran great and got me home without problem.
But ... after a week of sitting in the garage, the fuel had drained back down through the system, and into the tank. Thus the line was empty.
The electric wasn't strong enough to pull fuel through the "empty" part of the line, to be able to push it onward to the engine.
The pump had been designed as a "push" type, to be mounted just forward of the tank. In my emergency setup, when the line was already full of fuel, if worked fine. But not when the line was empty.
My two cents.
Tom
CJD
No, it will not hurt anything to run both pumps in line. We used to do this as a rule in the old Chevy's I used to race. The mechanical pump just has a couple check valves that the electric pump will push the fuel right on through.
The only thing to watch is the filter in the mechanical. If it was the original problem (as in clogged) is is still going to be a problem now.
John
TR3driver
Great Pumpkin - R.I.P
Ditto the diaphragm.
T
tdskip
Thanks guys.
This is all a bit theoretical as I'll replace the mechanical pump, but is there a risk of blowing out the seal and getting fuel into the block? Or, since the pressures are the same, is that a non-issue?
TR3driver
"blowing out", no. But if it fails from old age or perhaps not being compatible with gasohol, it can still leak fuel.
Geo Hahn
I carry an electric pump as a 'get-home' spare but I always bypass the mechanical pump when I use it. I connect it to the (undone) soft line that goes into the pump fitting and to the hard line that goes to the bowls (have long 5/16" to 1/4" hose on the output end). Of couse that set-up which is easy on a TR3 or 4 may be more cumbersome on a TR6.
My reasoning is that a failed mechanical (depending on the failure) might allow fuel to get pumped into the crankcase. Perhaps that is not possible?
CJD
It normally spews out the vent hole on the pump. But, with enough pressure and a large enough hole in the diaphragm, it is possible.
John
TR3driver
I had the opposite problem (although on a TR3A rather than TR6). The diaphgram was only leaking a small amount of fuel, but it wound up in the crankcase. I only knew there was a problem when the oil level went up instead of down.
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
knad2208 Bypassing Emission Controls Spridgets 11
T Bypassing igntion switch Spridgets 6
B Bypassing Brake Booster Austin Healey 18
N Bypassing/Hot wiring a bugeye Spridgets 10
S TR2/3/3A Mechanical buddies. Triumph 2
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
A BN1 Mechanical Brake Switch Austin Healey 23
B TR4/4A Mechanical fuel pump vs electric Triumph 16
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
K TR4/4A Mechanical fuel pump glass bowl level? Triumph 1
M Mechanical fuel pump Spridgets 33
M BE Mechanical Fuel Pump - Almost Certain Leak Spridgets 3
D TR2/3/3A Mechanical Fuel pump Triumph 3
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
AUSMHLY Watson Mechanical Brake Light Switch Austin Healey 13
tmcarthur Mechanical Fuel Pump Spridgets 9
J Mechanical tachometer to electric Austin Healey 11
DanLewis How far is your mechanical fan from the rear of your radiator? Spridgets 39
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
P Bugeye Wiper Mechanical Parts needed Spridgets 1
DanLewis Distance between mechanical fan and radiator core Spridgets 17
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
regularman What was wrong with the 1500 mechanical fuel pump? Spridgets 20
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
T Mechanical tach options? Spridgets 17
B Mechanical & body service parts manual BJ7/BJ8 Austin Healey 2
S Mechanical Tach Repair and calibration Austin Healey 5
T More on mechanical fuel pumps Triumph 32
glemon stupid human tricks mechanical advance Triumph 25
bigjones The 1500 mechanical fuel pump Spridgets 21
S Mechanical Tach Problem Debugging Austin Healey 2
pjsmetana Electric Fuel Pump or carry a spare Mechanical? Triumph 15
pjsmetana Mechanical Sunpro Oil/Water Temp Gauge Triumph 5
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
TR6oldtimer TR6 TR6 Distributor mechanical advance question Triumph 4
veale001 Mechanical or Electric Fuel pump? Triumph 15
prb51 TR2/3/3A TR3 Op temp issue and mechanical gauge Triumph 7
philman Mechanical Oil Pressure Gauge Question???? Restoration & Tools 2
emann BE Mechanical Fuel Pump Installation Spridgets 0
E Body Blasting and Mechanical Work Triumph 9
7 springs for a lucas mechanical advance Triumph 1
Atrus Dizzy – Mechanical Advance Weights Spridgets 19
W Mechanical Fuel Pump Rebuild Spridgets 1
S Electric Fuel Pump vs. Mechanical Pump Triumph 18
Michael Oritt Guages--mechanical versus electrical Racing 31
drooartz Mechanical fuel pump with later 1275 Spridgets 2
