Mechanical & body service parts manual BJ7/BJ8
bob hughes
Hi guys
Just aquired a parts manual for the BJ7/BJ8 cars, this manual is in a dark blue clip folder and has 'prepared by the AUSTIN HEALEY club of America' on the back of it in white outline. the the manual looks to be a photocopy of the real thing on good quality paper, so it is not to bad, but not the original that I had thaught it was.
The folder itself looks to be a purpose made one with white print on the front with three clips inside, not something that was a one off, but part of a run, possibly commissioned by the club as it is of professional quality
Does any one know anything about this / these manuals from you side of the pond?
Bob
The Austin-Healey Club Pacific Centre (California) was reprinting manuals as early as the mid-70s, but at that time, they were in a plain blue vinyl 3-ring binder.
I'm sure that they were done with the blessing of the Healey Clan.
E Body Blasting and Mechanical Work Triumph 9
S TR2/3/3A Mechanical buddies. Triumph 2
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
A BN1 Mechanical Brake Switch Austin Healey 23
B TR4/4A Mechanical fuel pump vs electric Triumph 16
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
K TR4/4A Mechanical fuel pump glass bowl level? Triumph 1
M Mechanical fuel pump Spridgets 33
M BE Mechanical Fuel Pump - Almost Certain Leak Spridgets 3
D TR2/3/3A Mechanical Fuel pump Triumph 3
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
AUSMHLY Watson Mechanical Brake Light Switch Austin Healey 13
tmcarthur Mechanical Fuel Pump Spridgets 9
J Mechanical tachometer to electric Austin Healey 11
DanLewis How far is your mechanical fan from the rear of your radiator? Spridgets 39
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
P Bugeye Wiper Mechanical Parts needed Spridgets 1
DanLewis Distance between mechanical fan and radiator core Spridgets 17
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
T Bypassing the mechanical fuel pump Triumph 8
regularman What was wrong with the 1500 mechanical fuel pump? Spridgets 20
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
T Mechanical tach options? Spridgets 17
S Mechanical Tach Repair and calibration Austin Healey 5
T More on mechanical fuel pumps Triumph 32
glemon stupid human tricks mechanical advance Triumph 25
bigjones The 1500 mechanical fuel pump Spridgets 21
S Mechanical Tach Problem Debugging Austin Healey 2
pjsmetana Electric Fuel Pump or carry a spare Mechanical? Triumph 15
pjsmetana Mechanical Sunpro Oil/Water Temp Gauge Triumph 5
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
TR6oldtimer TR6 TR6 Distributor mechanical advance question Triumph 4
veale001 Mechanical or Electric Fuel pump? Triumph 15
prb51 TR2/3/3A TR3 Op temp issue and mechanical gauge Triumph 7
philman Mechanical Oil Pressure Gauge Question???? Restoration & Tools 2
emann BE Mechanical Fuel Pump Installation Spridgets 0
7 springs for a lucas mechanical advance Triumph 1
Atrus Dizzy – Mechanical Advance Weights Spridgets 19
W Mechanical Fuel Pump Rebuild Spridgets 1
S Electric Fuel Pump vs. Mechanical Pump Triumph 18
Michael Oritt Guages--mechanical versus electrical Racing 31
drooartz Mechanical fuel pump with later 1275 Spridgets 2
V Website about most any auto mechanical question Triumph 1
B Mechanical Fuel Pump Spridgets 3
WALTER mechanical fuel pumps Spridgets 12
MGTF1250Dave TR2/3/3A TR3 or 4 Mechanical Fuel Pump Blanking Plate Triumph 4
T Electric vs Mechanical fuel pump? Triumph 3
