Spitfire Electric fan
Duane3
**** all, I have a 1980 spit. My electric fan just quit. Just had complete engine rebuild and just about every important part has been replaced. I cannot get the fan to work.. Put new relay in. Put new temp sensor in, fuses are good, fan turns fine, When engine runs it starts to warm up and the fan just will not kick in. I guess I do not know what else to do. All wires are fine. Any would be appreciated.. got a lot of in this thing and it just seems cannot catch a break. This is my third spit, my 65 was the best.
poolboy
First thing, I would check the fan itself....Bypass the switch, the sensor and the fuse...connect the 2 fan wires to a 12 volt source and see if the fan actually works.
If it does, back trace the problem with the fan's wiring.
Duane3
Thanks,,DUH.. I am going to order the replacement fan, 10 blade and get rid of that stock that is on there .. regardless got to find whwere it is at.. could hard wire it with a switch if it is in the harness..however I do not how that could be. Thanks again. appreciated take care..
FlyingCat
I have a 1980 Spitfire, too, and had the same problem with the fan. Fan worked when wired directly, but when wired through the relay switch, not at all. I tried all the fixes, and finally said the heck with it. I wired a direct switch into the cockpit. I watch the temp gauge, and when the engine starts getting warm, I switch it on. Problem solved.
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
FlyingCat Spitfire Electric Radiator Fan Triumph 10
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
B Electric fan Austin Healey 2
rjc157 TR6 Electric fan Triumph 5
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
S TR4/4A electric fan Triumph 6
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
R TR4/4A Thinking About an Electric fan Triumph 10
rjc157 Electric radiator fan Austin Healey 11
G TR2/3/3A Electric Fan controllers Triumph 4
R TR6 TR6 Electric Fan Triumph 10
longbridgehealey Electric fan for Bugeye Spridgets 6
sqbsprite TR6 Electric cooling fan switch - where is best location to mount? Triumph 2
GTP1960 TR2/3/3A Electric fan wiring Triumph 11
Rut Electric fan Spridgets 11
Tinkerman electric fan for my TR 3 Triumph 13
This14u Another Electric Fan Thread-What to Buy? Triumph 2
Crankshaft Electric fan question Triumph 19
HealeyRick Electric Cooling Fan Install Austin Healey 5
M Electric cooling fan Triumph 2
A Manual Electric Fan Triumph 6
George Zeck Electric Fan & Tranny coller ??? Spridgets 8
hondo402000 TR6 Electric Fan help needed for TR6 Triumph 5
TR4A_IRS Electric Fan Question Triumph 34
tmc TR2/3/3A Hayden electric fan kit - - TR3A Triumph 15
M TR4/4A TR4A Electric fan wiring ? Triumph 2
BugeyeNJ58 Push or Pull - Electric Fan Spridgets 3
M Electric fan and shroud for a 100 4 Austin Healey 3
R upgrade to electric cooling fan? Spridgets 17
M electric fan ? Triumph 3
C WHICH ELECTRIC FAN BEST FOR 67 3.8 S ? Jaguar 3
bigjones 1500 - electric cooling fan Spridgets 6
eschneider custom electric radiator fan switch Lotus 3
Mark Jones Electric radiator fan replacement options Triumph 3
D Electric Fan Size Spridgets 5
bighealeysource add on electric fan for BN6 Austin Healey 33
OregonTR4A Electric fan woes Triumph 5
K Spitfire Electric Fan- Spitfire Triumph 10
RJS TR4/4A TR4A Cooling Fan Upgrades - Non Electric Triumph 5
mountainman Electric Fan Choice? Triumph 3
mountainman TR2/3/3A TR3 Electric Fan/Reg Fan Triumph 11
deadair TR2/3/3A TR3/4 Electric Fan Conversion Triumph 42
wangdango XKE electric fan brushes? Jaguar 7
mountainman TR2/3/3A TR3 Electric Cooling Fan Triumph 8
