Electric Fan Choice?
mountainman
I am going to install an electric fan on my Tr3. does anyone here have any recommendations. How about the one from the big three?
Thanks
Greg
deadair
This topic has been covered:
https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/619518/
https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/618248/
https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/533959/
The Hayden fan from The Three may not pull enough CFM for your application. SPAL fans appear to be a better bet:
https://www.a1electric.com/catalog/cat_spal.htm
I ordered a Hayden (cheaper from another auto parts supplier), but sent it back after discussions with other forum members.
After giving this a lot of thought, I've decided to go with an 11" SPAL Medium Profile (970CFM) puller configuration on my TR3 and I'll be building a fan shroud for maximum flow. I'd go with the higher performance 1390CFM fan, except it would draw too many amps from my tired old generator and it would probably make more noise than is desirable.
alfa33047
Hi Greg, I live in Phoenix, Arizona, I use a 12 inch hayden fan, using an on/off switch. I flip the switch on once the motor is running and leave it on until I turn the motor off. I run a closed system radiator with a 7 lb. cap. My TR-3 has an old motor and runs 210 degrees on a hot summer day and I have used this set up for 3 years. I removed my front pulley snout from the sheet metal pulley halves. I took my trusty Saw-all and cut the tapered end of the snout and the flange that the fan bolts to, leaving the thick (1/2 inch thick) mounting area to be bolted back to the sheet metal pulley halves. I then had to go to the hardware store and buy a shorter bolt and flat washer to replace the front pulley bolt. I just use the electric fan and thats all. Good Luck, Bill C. Mesa, Az.
TR6BILL
Spal, Spal, Spal. You have a myriad of choices and super quality. Plus, their wiring harnesses, temp sensors and relays are of the best quality. Check out their web site. www.spalusa.com
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
FlyingCat Spitfire Electric Radiator Fan Triumph 10
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
B Electric fan Austin Healey 2
rjc157 TR6 Electric fan Triumph 5
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
S TR4/4A electric fan Triumph 6
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
R TR4/4A Thinking About an Electric fan Triumph 10
rjc157 Electric radiator fan Austin Healey 11
G TR2/3/3A Electric Fan controllers Triumph 4
R TR6 TR6 Electric Fan Triumph 10
longbridgehealey Electric fan for Bugeye Spridgets 6
sqbsprite TR6 Electric cooling fan switch - where is best location to mount? Triumph 2
GTP1960 TR2/3/3A Electric fan wiring Triumph 11
Rut Electric fan Spridgets 11
Tinkerman electric fan for my TR 3 Triumph 13
This14u Another Electric Fan Thread-What to Buy? Triumph 2
Crankshaft Electric fan question Triumph 19
HealeyRick Electric Cooling Fan Install Austin Healey 5
M Electric cooling fan Triumph 2
A Manual Electric Fan Triumph 6
George Zeck Electric Fan & Tranny coller ??? Spridgets 8
hondo402000 TR6 Electric Fan help needed for TR6 Triumph 5
TR4A_IRS Electric Fan Question Triumph 34
tmc TR2/3/3A Hayden electric fan kit - - TR3A Triumph 15
M TR4/4A TR4A Electric fan wiring ? Triumph 2
BugeyeNJ58 Push or Pull - Electric Fan Spridgets 3
M Electric fan and shroud for a 100 4 Austin Healey 3
R upgrade to electric cooling fan? Spridgets 17
M electric fan ? Triumph 3
C WHICH ELECTRIC FAN BEST FOR 67 3.8 S ? Jaguar 3
bigjones 1500 - electric cooling fan Spridgets 6
eschneider custom electric radiator fan switch Lotus 3
Mark Jones Electric radiator fan replacement options Triumph 3
D Electric Fan Size Spridgets 5
bighealeysource add on electric fan for BN6 Austin Healey 33
OregonTR4A Electric fan woes Triumph 5
K Spitfire Electric Fan- Spitfire Triumph 10
RJS TR4/4A TR4A Cooling Fan Upgrades - Non Electric Triumph 5
mountainman TR2/3/3A TR3 Electric Fan/Reg Fan Triumph 11
deadair TR2/3/3A TR3/4 Electric Fan Conversion Triumph 42
wangdango XKE electric fan brushes? Jaguar 7
mountainman TR2/3/3A TR3 Electric Cooling Fan Triumph 8
