Electric fan
Rut
When installing the temp sensor for an electric fan is it best to place it in the head or radiator? I have the 5/8x18 adapter in both and will use one for the fan and the other for the gauge.
Thanks, Rut
I agree with Patrick. That is how mine has been set up for several years now.
RickB
Also how mine is set up, with a variable temperature control so I can set where I want the relay to latch.
Rut
Rut
Thanks guys! Rick, what parts did you use for the sending unit, control switch, and fan? My local auto parts/machine shop ordered a 'sensor' for me yesterday to check fit and I want to make sure I get the correct one.
Rut
nomad
Just for thought, I would consider fitting the temp sensor for the fan in the bottom radiator hose. Recently cooked my son's Datsun pickup using a temp sensor at the top of the radiator. The rad had a small leak that he wasn't aware of and once the radiator coolant level got low the fan didn't run! If the sensor had been in the bottom hose that would not have been a problem. That's where the factory's locate them.
Kurt.
Jim_Gruber
Yes but how does one get a sensor inside of the radiator hose, this sounds like and interesting fix?
Jim_Gruber
Oh that is absolutely a trick piece. And only $12.00. Why would you want to try and get something to fit and seal in a 50 y.o. + radiator. I'm impressed.
dklawson
Those temperature sender adapters are sold by many vendors on eBay in different sizes. I like the part in the link above since the part is black. Most of the eBay parts are either the red or blue anodized coating common on AN fittings. I believe you will find that the tap for the sender is also available in a couple of different sizes.
Keep in the back of your mind that many mechanical temp gauges use 5/8-18 threads. You probably don't want that size for your fan switch since there are not a lot of compression fittings and/or adapters for that size. I anticipate you will want either a hose adapter that is tapped 1/4- or 1/8-NPT depending on the type of fan switch you have.
nomad
Need to remember also that that is the cool side of the radiator so you may want the temp settings for your sender to be lower.
Kurt.
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
FlyingCat Spitfire Electric Radiator Fan Triumph 10
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
B Electric fan Austin Healey 2
rjc157 TR6 Electric fan Triumph 5
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
S TR4/4A electric fan Triumph 6
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
R TR4/4A Thinking About an Electric fan Triumph 10
rjc157 Electric radiator fan Austin Healey 11
G TR2/3/3A Electric Fan controllers Triumph 4
R TR6 TR6 Electric Fan Triumph 10
longbridgehealey Electric fan for Bugeye Spridgets 6
sqbsprite TR6 Electric cooling fan switch - where is best location to mount? Triumph 2
GTP1960 TR2/3/3A Electric fan wiring Triumph 11
Tinkerman electric fan for my TR 3 Triumph 13
This14u Another Electric Fan Thread-What to Buy? Triumph 2
Crankshaft Electric fan question Triumph 19
HealeyRick Electric Cooling Fan Install Austin Healey 5
M Electric cooling fan Triumph 2
A Manual Electric Fan Triumph 6
George Zeck Electric Fan & Tranny coller ??? Spridgets 8
hondo402000 TR6 Electric Fan help needed for TR6 Triumph 5
TR4A_IRS Electric Fan Question Triumph 34
tmc TR2/3/3A Hayden electric fan kit - - TR3A Triumph 15
M TR4/4A TR4A Electric fan wiring ? Triumph 2
BugeyeNJ58 Push or Pull - Electric Fan Spridgets 3
M Electric fan and shroud for a 100 4 Austin Healey 3
R upgrade to electric cooling fan? Spridgets 17
M electric fan ? Triumph 3
C WHICH ELECTRIC FAN BEST FOR 67 3.8 S ? Jaguar 3
bigjones 1500 - electric cooling fan Spridgets 6
eschneider custom electric radiator fan switch Lotus 3
Mark Jones Electric radiator fan replacement options Triumph 3
D Electric Fan Size Spridgets 5
bighealeysource add on electric fan for BN6 Austin Healey 33
OregonTR4A Electric fan woes Triumph 5
K Spitfire Electric Fan- Spitfire Triumph 10
RJS TR4/4A TR4A Cooling Fan Upgrades - Non Electric Triumph 5
mountainman Electric Fan Choice? Triumph 3
mountainman TR2/3/3A TR3 Electric Fan/Reg Fan Triumph 11
deadair TR2/3/3A TR3/4 Electric Fan Conversion Triumph 42
wangdango XKE electric fan brushes? Jaguar 7
mountainman TR2/3/3A TR3 Electric Cooling Fan Triumph 8
