OregonTR4A
Member
Hi all
I purchased an aluminum radiator and a Spal fan to go with it for my TR4A. The radiator comes with the brackets welded on. It is an OEM radiator and bolts right in. I was under the assumption that it would fit with the old fan still in place but there is no way. I was told I could remove the old fan but it will still rub. Can the fan hub extension be taken off if a shorter crank bolt is used? Has anyone had this problem? Any suggestions? The top brackets are the main culprits as they seem short and put a cant on the radiator.
Thanks
Thanks
