Wedge Stripped gearbox filler hole thread
JFS
Bronze
My TR8 has a stripped gearbox filler hole and I only have myself to blame because I am the only one who serviced it over the last 20 years. I will put some RTV on the upper plug threads as a temporary fix until I figure out a more acceptable repair. Any ideas?
bobhustead
Find the thread and diameter of the plug, buy a tap in that size and thread and try to chase the threads BEFORE you do anything else. And put a ton of grease on the tap to catch as many aluminum crumbs as possible.
Bob
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 8
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 1
S Stripped Threads Austin Healey 10
Basil 7 Ways to remove stripped screws Restoration & Tools 2
B Stripped Thread in Gas Tank Austin Healey 26
G TR4/4A Well...another stripped trunnion Triumph 8
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
M stripped threads on master cyl Spridgets 12
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
Johnny SU fuel pump banjo fittings stripped out Austin Healey 19
F New set of lug studs and stripped spines.... Triumph 12
P Stripped hood latch bolt Triumph 5
TRMark Being my own DPO, stripped front sealing block Triumph 6
J Stripped threads engine block Triumph 7
L Stripped windshield frame screw hole Spridgets 6
K Painting a car not stripped to bare metal? Triumph 6
TRclassic3 stripped pan bolts Triumph 4
Lon_S Stripped a cylinder head nut Spridgets 7
DanNagy Spitfire Spitfire 4: Stripped Triumph 5
I Stripped screws in Bugeye windshield frame Spridgets 10
Tr3aguy Stripped and resprayed pics Triumph 4
Tr3aguy Stripped parts...yes Triumph 8
H Stripped headbolt Triumph 23
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
Don Elliott TR2/3/3A Stripped threads - TR3A block RHS rear ead stud Triumph 9
tinman58 TR2/3/3A stripped bolt TR3 Triumph 5
John Moore Big Milestone! Tub is stripped Spridgets 6
2wrench Help repairing stripped hole, rear overdrive case. Triumph 8
davidk Stripped threads in oil pan front saddle block Triumph 12
M Block threads stripped torquing head Triumph 16
John Moore Front End Stripped and Questions Spridgets 20
R interal thread stripped on timing chain cover Spridgets 2
F GT6 GT6 differential mount stud stripped... Triumph 3
S Stripped bolt on timing cover Spridgets 17
Nunyas Stripped manifold bolts MG 4
drooartz I have a stripped Midget! Spridgets 16
B Paint Stripped..now Moss Motors or Victoria Brit? Spridgets 7
TexBug Stripped door hinge screw removal? Spridgets 4
T Question on primer after getting fenders stripped Triumph 16
J TR2/3/3A TR3 Master Brake Cylinder Stripped Fitting Triumph 1
Mark_Gibson Body Weight of a Stripped Down TR-2? Triumph 10
MattP Stripped Shifter MG 0
6 Stripped exhaust manifold stud Austin Healey 5
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
