TR2/3/3A TR3 Master Brake Cylinder Stripped Fitting
jflynn
I rebuilt the master brake cylinder of my 1959 TR3 but I fear I have stripped the female threads where the brake line mates with the cylinder. I'd try retapping it if I knew the right size thread. Anyone know the right size? Any other ideas?
TR4nut
Jim-
This may not be right as I have a TR4, but on my setup the fittings are 3/8-24. I know because I was worried I did the same thing when I crossthreaded the brake line fitting to the cylinder.
Good luck
Randy
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
K TR2/3/3A TR3 Brake & Master Cyl "C" clips? Triumph 2
Q TR2/3/3A TR3 Brake Master cylinder rebuild Triumph 5
mctriumph TR2/3/3A Defective master cylinders Tr3 Triumph 13
mgedit TR2/3/3A Master Cylinder 56 TR3 [Lockheed] Triumph 14
mgedit TR2/3/3A Lockheed Master Cylinder 56 TR3 Triumph 2
T TR2/3/3A Is there a Silicon safe Master Cylinder for TR3? Triumph 21
mgedit TR2/3/3A 56 TR3 Master Cylinder Issues Triumph 17
mgedit TR2/3/3A Master Cylinder 56 TR3 Triumph 3
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
PeterK TR2/3/3A Classic Gold TR3 Master Cylinder Triumph 2
mrv8q TR2/3/3A TR3 Clutch Master Cylinder Triumph 20
T TR2/3/3A tr3 timing chain question [master link] Triumph 2
Tinkerman TR2/3/3A TR3 Master Cylinder Box Mounting Triumph 9
H TR2/3/3A TR3 Master Cylinder Removal Triumph 5
martx-5 TR2/3/3A Follow-up on TR3 Master Cylinder Resevoir Triumph 2
TRJohn TR2/3/3A TR2 TR3 master cylinders Triumph 2
txtr3 TR2/3/3A TR3 master cylinder replacement hints Triumph 3
