since I have the time before the frame is attached to the body I have done some maintance . A new oil pan gasket was in order so I pulled the pan cleaned every thing purchased new bolts and washers and as I was torquing the last bolt, and it never torqued!! The thread is stripped and of course it is the one ine the front center on the main bearing block. Can I put a heila coil in? Has any body have any experiance in this problem?
Dan
Dan
