Leaking Overdrive and Gearbox Drain Plugs
bighealeysource
Bronze
Hey Y'all,
Any suggestions on how to get rid of very slow but always there oil drips from transmission drain plug and the overdrive drain plug on a BN2?
I have tried a couple of different loctite-type products on the threads, but still gets by it. Tried yellow teflon type tape which is used on natural or propane gas connections. Replaced the trans plug, but doubt that quality was any better than the one I took out. I do install the fiber drain plug washer on the overdrive, but have always questioned the fit on those make it ineffective.
Any suggestions to rid my Healey of these annoying minor leaks?
Thanks,
Mike
gonzo
Most Loctite sealing products work great on machined surfaces. I use light application of Permatex Ultra Grey or the green one for "Gear-Oil" on threads and the OD drain plug sealing surface. Then again, my transmission likes to drip elsewhere.
This has been a bugaboo of mine as long as I've owned a Big Healey (going on 40 years). The 'stock' fiber washer is too hard IMO--I do soak them in oil to try to soften them up before installing--but I don't know if an O-ring or softer material would work either. Like you, I've tried various sealants, and I have a special socket for use on the notched big brass cap. I use synthetic oil, which likely makes things worse but I've managed to otherwise seal up my gearbox and O/D pretty well. My recently rebuilt unit just dumped a half-quart on the garage floor, but I managed to tighten the cap a few degrees so we'll see what happens (the fiber washers do seem to take a set and need re-tightening).
This stuff worked for me to seal up a water pump plug when nothing else short of brazing would, I may give it a try on the O/D cap:
For the gearbox and differential plugs normal thread sealant has worked well.
Michael Oritt
Hey Y'all,
Thanks,
Mike
Not having OD on my car I don't know if that drain plug will accept a copper crush washer but I use them throughout my cars and anneal them when draining and changing lubes. I have the usual small weeps in the usual places but not at or through the plugs.
This drain plug is, maybe, 2-2&1/2" in diameter; I don't know where you'd get a copper washer that big but, yeah, that would probably work.
bighealeysource
bighealeysource
Bronze
Thanks guys ! I have some of the High Performance Permatex thread sealer. How do you handle the problem of
threading it into the female fitting since that will have oil still dripping out ? I know that's kind of a stupid
question but getting that last few drops out seems impossible and contaminates the newly applied thread
sealer. Should be letting the thread sealer "set up" before screwing it in ?
dezand
Seems as those are too small, the ID of a new fiber washer being 2.08"
When I recently rebuilt my overdrive I took a good look at the sealing surface of the aluminum housing because I had a leak there for over 40 years regardless of the oil changes and new sealing washers. There were some defects such as pits and scratches, but the big problem showed up when placing a machined short aluminum round, face to face with that surface. Clearly it was not flat.
So I contact cemented some 320 grit wet to the round bar and lapped the OD surface and then transitioned to 400 grit and then 600 grit. The sealing surface was now flat and using a new fiber washer, the OD is now leak free. I did add some white teflon tape to the threads, being careful not to let any go lower than the 2nd to last thread.
Michael Oritt
I thought the ID of the copper crush washer shown in my post was 2.25" but in any case I'd check out that source.
Also, leaks due to metal porosity, esp. in AL castings are quite common. The materials used in our cars often came as scraps from WWII leftover aircraft, etc and as such was less than the best. The AL sump of the FWB Coventry Climax engine in my Elva MK IV SR is obviously an old casting and oil sweats right through, though a good coating of Glyptol helped out.
bighealeysource
bighealeysource
Bronze
Thanks everyone for their suggestions ! Going to try the pink teflon tape on trans plug and see about the crush washer for the OD plug.
dezand
In general the color of the tape is only for identification purposes. PTFE is PTFE, white or pink still seals the same, oil or water.
Some colors are thicker and denser though, mainly for natural gas sealing, since the natural gas molecules are smaller than water or oil molecules.
Wato
An old mechanic said to put the fibre washers in boiling water to soften them then tighten it up and you get a better seal.
bighealeysource
bighealeysource
Bronze
Looks like the vendor Michael Oritt referenced might have one. I get 1.98 ID if you measure on the flat side of the top of the large brass plug - just beyond the threads - and 2.35 OD on the diameter of the actual plug. If you can squeeze the crush washer over the threads (???) would be a good fit. Guess that's the crux of the problem is getting it over the threads as that measurement is 2.10. I have asked the vendor if they have something available.
Has anyone tried the same type of gasket sealant used on valve covers - RED RTV Silicone gasket maker ? That would be pliable when cured and would seem to make a decent seal. Or a rubber O ring that fits well ?
Also, good suggestion about trying boiling the fiber washer, sure don't seal as is.
bighealeysource
bighealeysource
Bronze
Hey y'all,
I have gone ahead and tried an O ring in lieu of the hard fiber gasket for the OD drain plug. It is a metric sized one and fits very tight and seems to be doing the job. No leaks from that plug so far. Buddy of mine said that after time oil might degrade it so will keep a watch. Still going to try
and get a crush washer but thinking one of those that would fit tightly will not be able to be forced over the threads.
Hey y'all,
Mike, rather than force it over the threads, try to thread it on; a slight V-notch on the i.d. may ne necessary to get it started...
Coincidentally, immediately before sitting down at this website, I was examining the offending port on a BCF member's* overdrive! At a minimum, I will make it flat__it is not at present__but dezand makes a good point about checking that it's perpendicular to the port face too!
* while still very much a work in progress (waiting on a relatively small parts order, as that's all that was required) here's a photo-documentary on the absolute best existing original condition BN6 overdrive I have ever seen: > DR_HLY-OVD | spcarsplus.com photo gallery <
Note that there will be a 2-week hiatus beginning next Saturday when head to the beach to work on our tans (ironic sarcasm, we're more naturally pale than anyone living in Florida has a right to be) my point is, if you're one of the 1 or 2 people checking for updated pictures, don't give up ;)
bighealeysource
bighealeysource
Bronze
Hey Randy,
How's my BN6 buddy doing ? Sounds good and have seen on FB you've had some medical issues but being 75 myself, new ones come
up all the time ! Still hanging in there with the 100M but a black over red BN6 at the British Car Club of Charleston show this weekend
sure brought back good memories on BN6 964. Thanks for the advice on the crush washer, I will try it that way. Plus getting ready to
watch the photo doc you sent over. The rubber O ring is holding good but cautious with the long run.
Regards,
Mike
D Overdrive Leaking Oil Austin Healey 4
AUSMHLY Help with tranny overdrive leaking Austin Healey 3
pan Leaking Welsh Plug in Overdrive Austin Healey 1
S Leaking HD6 Rear Carb Austin Healey 10
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
S TR2/3/3A rear main seal is leaking Triumph 13
R TR2/3/3A Leaking O.D. section of Transmission Triumph 43
E Oil leaking from the Tachometer cable Austin Healey 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
PatGalvin TR2/3/3A Leaking SUs. Advice badly needed Triumph 15
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Michael Oritt Leaking oil pan Racing 8
T TR6 leaking carb TR6 Triumph 17
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
Rob Glasgow Leaking tapered plug on head Austin Healey 8
Scotsman TR2/3/3A leaking front engine plate Triumph 4
bigbadbluetr6 TR6 Carb leaking Triumph 12
