KVH
I put new copper washers on the stud and housing, on each side of the banjo nut at the oil pressure line and housing. It appears the one on the housing side is leaking rather badly. I don't want to over-tighten that cap nut fitting.
I'm actually not sure there ever was a copper washer on the housing side. I'm wondering if I should've just installed one on the outer side. My banjo nut fitting is, itself, copper. Is the problem that washer I added? The Moss parts diagram shows it, and I ordered it like a good lad, but my banjo nut fitting never leaked before. When I took the whole thing apart I heard a clanging on the floor but could only find one copper washer and that has me wondering.
Should I try gasket sealer or a thin gasket?
Any help on this latest? Thanks
