1275 engine oil pressure warning light? oil filter warning light??
twas_brillig
We're installing the wiring kit in our BE and the 1275 cc engine has a male electrical spade connection on the oil filter housing. The BE instrumentation has an oil pressure gauge but no warning light; I found an on-line MG Midget Mark III Owner's Manual https://www.1978mgmidget.com/1967_Midget_Owners_Manual.pdf that identifies a "Oil filter warning light (amber). The warning light indicates the need to change the oil filter element and engine oil (see page 18)." - the oil filter was the non-spin on, replaceable element type in the manual (the engine's converted to spin-on).
I am curious about using a warning light for an oil filter change, but the implication is that it is not an oil pressure warning light. We won't bother connecting it to anything, but I'd be interested in comments as to its effective purpose. Thanks, Doug
Gerard
This was a feature on the 1098 engine, but not the 1275. Some dummy lights were added to the dash on later Sprites, but I don't think there were ever indicators in the instruments themselves. Other BMC cars, like the Morris Minor, which was not factory equipped with a gauge, had lights in the instruments. I don't think that filter housing was used for very long. I think I have only run into one of those once.
nomad
Warning light on the 10CC steel dash cars for too HIGH pressure. [Plugged filter]. I wired it up to the low pressure switch on my Datsun transplant along with the normal BMC gauge. Always nice to have a red warning light. Anyone with a steel dash car with the oil warning lamp I always thought could add the same low pressure switch.
Kurt.
SaxMan
Midget Mark III = Sprite IV -- I don't have that light or an accommodation for it on the dash, but I have the padded dash, too. Just an oil pressure gauge.
nomad
Only the Mk2 Midgets and the Mk3 Sprites had the steel dash with the light. Just had to be anal and get it to actually be useful!:rolleye:
Kurt.
B Oil cooler engine adapters for a 1275 Spridgets 10
CARSINC WANTED: 1275 Engine Spridgets 0
D A distributer question on the 1275 engine. Spridgets 7
AngliaGT 1275 Engine Value? Spridgets 5
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
A Bugeye engine swap, 948 to 1275 Austin Healey 11
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
V Wanted rebuildable 1275 engine Spridgets Classified 0
AngliaGT Picking up a 1275 Engine Spridgets 6
R 1275 engine with SU HIF single carb Spridgets 9
T Weber for a 1275 cc engine? Spridgets 6
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
M Help me ID a couple of bolts on my 1275 engine... Spridgets 5
C 1275 fuel injected mini engine in a sprite? Spridgets 7
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
B MG Motor - 948 parts or 1275 engine MG 1
I Bugeye 1275 engine conversion questions Spridgets 3
A best year for 1275 engine? Spridgets 3
M 1275 Engine Rebuild - Especially Hap! Spridgets 11
6 1275 engine compression Spridgets 2
6 1275 engine compression Austin Healey 2
mccalebr Hap's 1275 engine builds for Ray and Drew Spridgets 15
Bruce_B Source for Motor Mounts for 1275 engine? Spridgets 4
C 1500 to 1275 engine conversion Spridgets 21
athenssprite How to differentiate 1275 engine vs smaller Spridgets 5
racingenglishcars 1275 Marina engine Spridgets 23
M 1275 Engine Paint Schemes? Spridgets 7
Bruce_B Painting 1275 engine - Questions Spridgets 44
Bruce_B 1275 Engine Rebuild - It starts this weekend! Spridgets 19
Bruce_B 1275 Engine Returned from Machine Shop Spridgets 12
B 1275 Engine Rebuild Cost Spridgets 6
Banjo in need of a 1275 engine Spridgets 6
George Zeck 1098 v. 1275 engine transplant ?? Spridgets 13
D Swapping 948 for 1275 engine Spridgets 11
R Value of rebuilt 1275 Engine, new clutch & rib trn Spridgets 6
A Distributor 1275 engine Spridgets 2
klutterbutt 1275 on an engine stand MG 14
nathandarby67 Head swap for 1275 engine? MG 4
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
