Head swap for 1275 engine?
nathandarby67
Looking through my shop manual, it shows the 12V series 1275 engines such as in my 73 Midget as having 8.0:1 compression ratios, while earlier 1275 engines have 8.8:1 ratios, and you guessed it, more power. Is this difference in compression due to diffenret cylinder head designs, or are there other differences such as pistons, etc? When all is said and done, what would be the easiest way to increase compression in my engine? If I could find a head from an earlier model, is it a direct bolt-on swap or are there other modifications that have to be made?
aeronca65t
The compression difference is mostly pistons (more "dished" on the low-comp 1275).
aeronca65t
All 1275 heads will interchange (including heads from the low-performance 1300 Austin sedan). Biggest problem with these heads is exhaust seat cracking.....I saw three cracked 1275 heads for sale in the last year (and I've had several fail myself).
The best heads are the Mini-Cooper 1293 heads...and I think there are aluminum heads available now too (check minimania.com for these)
[ 06-02-2003: Message edited by: aeronca65t ]</p>
Bugeye58
If you are looking for performance, and are willing to do a little port work, the 12G1316 castings are the ones to work with. They are the ones with the smog ports, which are easily plugge using #4 AN or SAE steel plugs. They are less prone to cracking than most of the 12G940 castings.The best one to use is the Cooper "S" casting, #AFG163, but those are getting harder to find.
Jeff
aeronca65t A-Series head swap Spridgets 3
Brosky Cylinder head swap on web site Triumph 12
Brosky When a good cylinder head swap goes bad... Triumph 34
Creatrixx Head swap on a 998cc? British Motor Corp 7
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
KVH General Tech Head Gasket Sealant Triumph 4
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
T TR2/3/3A Water pumps/head cooling Triumph 22
T TR2/3/3A cylinder head ,valves and springs Triumph 0
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
T TR2/3/3A tr3 head gasket Triumph 38
