Cylinder head swap on web site
Brosky
I finally got around to posting a lot of the pictures from my cylinder head swap on a page on my site. I still have to do the A/F meter install and start on the chassis overhaul soon, since I have nothing under the car from the frame to the ground except jack stands at this time.
Mucho scraping, sanding and cleaning before the POR15 application, but that's for another post.
https://www.74tr6.com/cylinderhead.htm
kodanja
Awesome documentation Paul!!!
cyaker
Thanks for taking the time to share the pictures. Any concerns about clearance with the shaved head?
Brosky
Brosky
Thank you, Bill.
Cyaker, the only issue is that we calculated that the original shop took of about .010" to .015" and I had another .080" removed for a total of .090"-.095".
If there were any more removed, I would have had to go to the shorter GT6 push rods.
Other that that, it goes like heck, no ping, no oil issues and now I just need to get the frame and suspension done.
DNK
Paul- could you do a TR8 head swap for me for future references? /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
G
Paul, when you eat your dinner, do you separate your food on your plate into sections???
Nice documentation.
NutmegCT
Paul - that is fascinating. I probably missed something - but what's the story behind the "rusted bolt [edit: stud]"? Did it "slip through the cracks"?
Any idea how the rust started there?
Thanks.
Tom
PS - that engine bay looks FANTASTIC! Bravo!
Brosky
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] do you separate your food on your plate into sections???[/QUOTE]
Actually, I do, but then I cover everything with gravy and mix it all up together before I eat it.
Darrell_Walker
Did you do a compression check after the new head was installed? It would be interesting to know how much the pressures increased.
Brosky
Brosky
No, but when we do the retorque, that will be on the list of "to-do's". Good point, thanks for bringing it up.
I don't think that it will go up much, since I had no burnt valves and I don't think that having a higher compression ratio will actually raise the compression any higher than before. It could be an oxymoron.
Brosky
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] but what's the story behind the "rusted bolt [edit: stud]"?[/QUOTE]
Tom, I'm not sure and I wish that I had a better picture to look it over more closely. At the time, we were rushing to get it done so I could go to the British legends weekend the next day, so I didn't much forensic work with the time that we lost.
This is about the best that I can do for now, but I have the head in the garage and when the frame is done, I'll pull it out and look at the hole for the stud and the bottom surface of the head. The gasket did look good around the stud, so who knows?
Brosky When a good cylinder head swap goes bad... Triumph 34
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR2/3/3A Cylinder head threaded plub Triumph 6
R BJ8 Cylinder Head Gasket Austin Healey 38
M Alloy cylinder head Austin Healey 5
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B General Tech Cylinder head costs MG 7
J For Sale TR 2, TR 3 TR 4 cylinder head Triumph Classifieds 6
J TR2/3/3A TR 4A cylinder head on TR 3 engine Triumph 15
M Planing a Jaguar cylinder head Jaguar 4
RJS TR4/4A Cylinder Head Install - Questions Triumph 16
C Wanted - 3000 cylinder head - uk based Austin Healey Classifieds 0
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Wanted 3.4 Cylinder Head Jaguar Classifieds 3
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
HealeyBN7 Is this a 100 Cylinder Head? Austin Healey 4
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
DornTRoriginal TR2/3/3A Head Gaskets and Shaved Cylinder Head Triumph 9
SherpaPilot TR6 Cylinder Head Stud Question Triumph 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
K TR2/3/3A Cylinder head valve springs? Triumph 3
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
KVH TR4/4A Cylinder Head Time For More Tools? Triumph 28
BOBBYR Cylinder head for sale on ebay Austin Healey 2
S Procedure for cylinder head removal and re-installation - BJ8 Austin Healey 11
S TR2/3/3A Cylinder head stud methodology Triumph 11
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
