TR2/3/3A Cylinder head threaded plub
Redoakboo
I am in the final stages of the restoration of my 54 TR-2. I cranked the engine for the first time. It ran O.K. but oil was flowing out a treaded hole in the rear of the head. It is obvious that something screws into this hole to keep it from flowing out? Is this just a treaded plug I forgot to install? Or does something else, oil related, go into this hole?
Dick
charleyf
Assuming that the TR2 and TR3 are the same. If the hole is on the driver's side it takes a bolt with a copper washer. This is a hole that opens to the galley where the oil to the rockers comes up from the cam below.
TomMull
Charlie's right. It's a 3/8 nc bolt and 3/8 inches long. If you can't find one that short, you could cut one. Make sure the threads go all the way to the bolt head. The washer is quite thick too. Perhaps double up if you can't find a thick one.
Tom
R
Redoakboo
Thanks Guys,
Missed it in the re-assembly. Good pressure as it vomited out about 1 qt of oil in several minutes! So all the bolt does it stop up the hole?
Couldn't find it either in the Moss or RF catalogs. Off the NAPA.
Dick
TomMull
Yup. Rimmer Bros. have it in their catalog but out of stock. Tom
2liter4cyl
Bronze
The only reason for the hole in the head is to cross drill a connection to the rocker arm pedestal oil hole. The wrench is a box end 14mm or 9/16".
It is cast at an outboard angle.
LeT
charleyf
It is usable as an alternate way to get oil to the rocker. There are aftermarket kits that have a line from the oil gallery along the cam line that tie into this hole. I have had to use this as I believe the shop that placed my rear cam bearing did not correctly line up the hole for the rocker oil flow. So in place of a tear down I installed the bypass line. But beware of using that the way it comes. I got so much more oil up there that I had to weld the orfice hole in the kit shut and drill it much smaller like under 1/16".
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R BJ8 Cylinder Head Gasket Austin Healey 38
M Alloy cylinder head Austin Healey 5
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B General Tech Cylinder head costs MG 7
J For Sale TR 2, TR 3 TR 4 cylinder head Triumph Classifieds 6
J TR2/3/3A TR 4A cylinder head on TR 3 engine Triumph 15
M Planing a Jaguar cylinder head Jaguar 4
RJS TR4/4A Cylinder Head Install - Questions Triumph 16
C Wanted - 3000 cylinder head - uk based Austin Healey Classifieds 0
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Wanted 3.4 Cylinder Head Jaguar Classifieds 3
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
HealeyBN7 Is this a 100 Cylinder Head? Austin Healey 4
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
DornTRoriginal TR2/3/3A Head Gaskets and Shaved Cylinder Head Triumph 9
SherpaPilot TR6 Cylinder Head Stud Question Triumph 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
K TR2/3/3A Cylinder head valve springs? Triumph 3
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
KVH TR4/4A Cylinder Head Time For More Tools? Triumph 28
BOBBYR Cylinder head for sale on ebay Austin Healey 2
S Procedure for cylinder head removal and re-installation - BJ8 Austin Healey 11
S TR2/3/3A Cylinder head stud methodology Triumph 11
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
B BN2 Cylinder Head Stud Thead Size/Replacement Austin Healey 0
TRspitfirefan TR4/4A Cylinder head issues? Triumph 5
