General TR Cylinder Head Gasket: Stay Simple?
KVH
Sorry I can't find the old posts: The preference around here is "no sealant" for the sandwich type copper cylinder head gaskets, correct? I'm not referring to the sold ones.
Also, what about that perforated steel core one sold by BPNW for about $70 that says: "Made by Lucas in the UK . . . best head gasket to use for your Big Bore 87mm to 90mm Piston and liner kit. These heavy duty gaskets are . . . . perforated steel core, stainless steel fire rings and elastomer surface coating that heats very evenly. . . .No blown head gasket. . . ."
TR3driver
Great Pumpkin - R.I.P
I tried several different substances when I was having trouble with head gaskets leaking. None of them seemed to help. Once I addressed the root cause (insufficient liner protrusion), they seemed to seal just fine dry.
No idea about the BPNW gasket, haven't heard of that one before. But _perforated_ doesn't sound good when it comes to sealing a surface.
glemon
I have used the Permatex copper head gasket spray on a number of jobs, I have never had a problem, but, kind of the opposite of Randall's comment, but I was installing gaskets on blocks and heads that had visited a machine shop and been cut smooth as needed, so I shouldn't have had any problems. I did use it on my Healey 100, which are notorious for leaking, it used a sandwich type gasket, I didn't get any leaks with the copper gasket spray. I don't know if that proves anything. I always put it in the category of can't hurt, might help.
Geo Hahn
I have used a coating in the past - plain aluminum spray paint - but doubt it made much difference and looked a mess when time can to remove it. Lately I just used the gasket 'as it comes'. If the protrusion is there these things don't seem too fussy or problem-prone.
mallard
The first two head gaskets I used on my engine leaked coolant. One was a Payen copper gasket the other was one of the Lucas you described above. Then BPNW and Lucas came up with the same style gasket with the with the red sealing bead around all the coolant passages. It has worked fine so far but only 1000 miles of driving. I did not have the top of the block machined flat, but I did do the head. At the time I was afraid the liner protrusion would be to big if I machined the block flat. Then I found you could buy different thickness figure 8 gaskets.
KVH
KVH
Which side of the copper sandwich gasket goes up? The one showing the folds of the copper?
TR3driver
Supposedly doesn't matter; but that's the way I do mine.
Tybalt
Same here, your basic plain aluminum spray paint, only difference is that I still use it, blame it on superstition.
R BJ8 Cylinder Head Gasket Austin Healey 38
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
S SaxMan's Cylinder Head Overhaul / Head Gasket Replacement Thread Spridgets 135
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
I Double Cylinder Head Gasket Horror ! Austin Healey 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR2/3/3A Cylinder head threaded plub Triumph 6
M Alloy cylinder head Austin Healey 5
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B General Tech Cylinder head costs MG 7
J For Sale TR 2, TR 3 TR 4 cylinder head Triumph Classifieds 6
J TR2/3/3A TR 4A cylinder head on TR 3 engine Triumph 15
M Planing a Jaguar cylinder head Jaguar 4
RJS TR4/4A Cylinder Head Install - Questions Triumph 16
C Wanted - 3000 cylinder head - uk based Austin Healey Classifieds 0
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Wanted 3.4 Cylinder Head Jaguar Classifieds 3
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
HealeyBN7 Is this a 100 Cylinder Head? Austin Healey 4
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
DornTRoriginal TR2/3/3A Head Gaskets and Shaved Cylinder Head Triumph 9
SherpaPilot TR6 Cylinder Head Stud Question Triumph 6
K TR2/3/3A Cylinder head valve springs? Triumph 3
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH TR4/4A Cylinder Head Time For More Tools? Triumph 28
BOBBYR Cylinder head for sale on ebay Austin Healey 2
S Procedure for cylinder head removal and re-installation - BJ8 Austin Healey 11
S TR2/3/3A Cylinder head stud methodology Triumph 11
