TR2/3/3A Cylinder head stud methodology
sp53
Cylinder head stud methodology, I have all ten head studs out and I am looking to install the head. I could put all ten studs in and try and drop the head down, or I could just put in a couple. The ones that go deep into the block would seem the most probable because of the need to feel them go in correctly. Then there is what happened to Keith’s engine when it looks like the studs might have been over tightened and the additional toque wrenching caused too much tightening and the block cracked. At least that is what Mad Max thought might have happened, and I consider him an expert. Anyways just looking for opinions and suggestions on how and when to install the head studs on a tr3.
Jerry
I install prior to putting on the head. I also like to put a little high temp silicone sealant around the threads, you could consider it a lubricant for installation, but I have seen TR3/4 leak around the studs. I then wipe up any excess around the base of the studs prior to installing the head. You do not need to tighten the studs into the block much. Just barely beyond hand tight is my practice.
Jerry
CJD
The studs go finger tight into the block, preferably using an anti-seize compound on the threads. I would install them first, but there is no reason I can think of you couldn't install them after the head.
These studs are dry...I.e. not exposed to coolant. So sealant is not necessary...but then, it shouldn't hurt anything using that for anti-seize.
6TTR3A
When re-using studs it's good idea to check them for "stretch". Using a (preferably new) head nut,
run the nut all the way down thru the threads on the top side of the studs. If there is ANY binding at all, the threads have been stretched. A stretched stud will give you a false (high)reading on your torque wrench, the end result of which is the dreaded leaky head gasket.
mallard
I had my torque wrench calibrated after the problem with the block and it came back with 1 percent error. I don't think that was the problem. The only thing I might add to the ideas above would be to install 4 studs in a square pattern to set the head gasket then install the rest of the studs. Sometimes the holes in the gasket aren't perfect. I did use ARP studs the second time.
alanjohnturner
We had a run of blocks with stripped threads and broken head bolts on the TR-register forum and did so research into this.
If you check the torque specs for UNC and UNF bolts a few intersting things will show up.
1. the torque for UNC is a good bit less than UNF,which is awkward on a mixed stud
2. there is a big difference in recommended torque between lubricated and dry bolts
3. a torque of 110 ft.lbs would want a Grade 8 UNC bolt
A TR block will not be a strong as a Grade 8 bolt and there will be some fatigue cracks by now.
So be careful and don't pull too hard on a lubed bolt.
mallard
Alan that's very interesting about the torque readings. I used the recommended lube on my ARP studs on both the course and fine threads. I torqued them down to the books 100lb recommendation. I've heard that lubes and sealants on threads may change the torque readings. Can you be a bit more specific on the findings? Do you build your engines with dry or lubed bolts?
martx-5
I used ARP studs and nuts, and used their recommendations that came with the studs. Basically it says "Torque values are based on 75% of the fasteners yield strength. Use the manufacturers torque sequence but do not use the manufacturers torque specs. Torque the nuts to 90 ft.lbs. with ARP moly assembly lubricant (or ARP thread sealer) or torque to 130 ft.lbs. with 30 wt motor oil". That's the difference that friction makes, even with oil.
That's right off the sheet they sent with the studs. I used their lube and torqued to 90 ft.lbs.
Edit: I can scan that sheet if anyone's interested. It has some other goodies mentioned also.
TR3driver
Great Pumpkin - R.I.P
Just a minor point, but when the factory data says 100-105 ft lb, the range is to allow for the precision of your torque wrench. In other words, they really mean 102.5 ftlb, plus or minus 2.5%
Also, the TR4 workshop manual specifies to install the studs before the head gasket (although I have no idea why). That's what I normally do as well. The TR2/3 manual doesn't really say, but shows several photos of the studs in place while working inside the engine (checking ring gaps and so on), plus of course using the studs to clamp the liners in place while installing pistons.
A professional mechanical engineer (who also worked on Jaguar engines in his spare time) once told me that studs should always be lightly torqued into their blind holes. Something about compressing the stud to spread out the load on the threads; I didn't really understand that part. But it seems to work for me.
TRTEL
Things like block castings tend to be a polycrystalline mess. So on a micro level there are hard, soft, ductile...etc. spots in the matrix. As the tap moves into a blind hole (or any hole) the swarf will carry these sometimes superhard materials (carbides, harder than the cutting tools alloy) along the cutting boundary before being hopefully expelled. The result being that finger tight really won't result in all internal and external threads making contact and more uniformly distributing the torque from the start. I suppose it would be an interesting experiment to test an old cracked block with some grade 8's to see where they let go, both dry and lubed.
CJD
The finger tight recommendation comes from Carrol Smith's "Engineer to Win". It's a very worthwile book all about bolts, studs, torques and how to do them right.
TomMull
The f0llowing might agree with Smith and seems to make sense to me. Tom
"By contrast, a head stud can be tightened into place without any direct clamping force applied through the tightening. A stud can be threaded into a slot up to “finger tightness,” or the degree to which it would be tightened by hand. Afterward, the cylinder head is installed and a nut is torqued into place against the stud. The nut torque provides the clamping force, rather than the torque of the fastener itself, and the rotational force is avoided entirely. Because the stud is torqued from a relaxed state, the pressure from the nut will make it stretch only along the vertical axis without a concurrent twisting load. The result is a more evenly distributed and accurate torque load compared to that of the head bolt. This ultimately translates into higher reliability and a lower chance of head gasket failure." https://www.thomasnet.com/articles/hardware/head-stud-bolts
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
SherpaPilot TR6 Cylinder Head Stud Question Triumph 6
B BN2 Cylinder Head Stud Thead Size/Replacement Austin Healey 0
Patrick67BJ8 Stud Locations - Cylinder Head & Exhaust Manifolds Austin Healey 3
Bruce_B 11 stud cylinder head for a 9 stud block Spridgets 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR2/3/3A Cylinder head threaded plub Triumph 6
R BJ8 Cylinder Head Gasket Austin Healey 38
M Alloy cylinder head Austin Healey 5
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B General Tech Cylinder head costs MG 7
J For Sale TR 2, TR 3 TR 4 cylinder head Triumph Classifieds 6
J TR2/3/3A TR 4A cylinder head on TR 3 engine Triumph 15
M Planing a Jaguar cylinder head Jaguar 4
RJS TR4/4A Cylinder Head Install - Questions Triumph 16
C Wanted - 3000 cylinder head - uk based Austin Healey Classifieds 0
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
T Wanted 3.4 Cylinder Head Jaguar Classifieds 3
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
HealeyBN7 Is this a 100 Cylinder Head? Austin Healey 4
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
DornTRoriginal TR2/3/3A Head Gaskets and Shaved Cylinder Head Triumph 9
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
K TR2/3/3A Cylinder head valve springs? Triumph 3
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
KVH TR4/4A Cylinder Head Time For More Tools? Triumph 28
BOBBYR Cylinder head for sale on ebay Austin Healey 2
S Procedure for cylinder head removal and re-installation - BJ8 Austin Healey 11
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
